Question about Ford Vehicle Parts & Accessories
Camshaft position sensor 2000 ford contour?
Locate sensor
  • 363 Answers
I think the sensor is found on front of engine block above the harmonic balance wheel. I know it is on the 2.oL 99 model.
Posted on Feb 27, 2012
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How to replace a throttle position sensor on a 2000 ford contour
Hey DonAld, these are not hard to replace..( I do not know which engine you have..it makes a difference!! ).. take a PICTURE of where the current TPS os positioned and located... the radial (adjustment) location IS critical!!..
here is a link to Autozone, ...O'Reilly's, and Advance Auto should have one too..
Ford Contour Throttle Position Sensor TPS
https://www.oreillyauto.com/shop/ignition---tune-up-16776/engine-sensors-17084/throttle-position-sensor-12043/2000/ford/contour?q=tps
Advance Auto Parts Down for Maintenance
Feb 03, 2017 | 2000 Ford Contour
Cant locate the camshaft position sensor on my 2000 ford contour 2.5L V6
On the 2.5 liter V6, it's just below the front cylinder bank valve cove
Jan 11, 2017 | 2000 Ford Contour
How do you change camshaft position sensor in 2000 ford contour
If you have a 2.0 liter 4-cyl, it's on the passenger side of the head on the firewall side. On the 2.5 liter V6, it's just below the front cylinder bank valve cove, on the passenger side, on the right side of the engine.
To remove the sensor:
  1. Disconnect the negative battery cable.
  2. On 2.0L engines, remove the air intake resonator.
  3. Unplug the connector from the CMP sensor.
  4. Remove the retaining bolt and remove the CMP sensor.
To install:
  1. Ensure the CMP sensor's mounting surface is clean, and the sensor's O-ring is in place.
  2. Install the CMP sensor and tighten the retaining bolt to 13-17 ft. lbs. on the 2.0L engine, and 71-106 inch lbs. on the 2.5L engine.
  3. Plug the CMP connector in.
  4. On 2.0L engines, install the air intake resonator.
  5. Connect the negative battery cable.
Feb 28, 2013 | 2000 Ford Contour
Where is the thermostat located?
Disconnect the camshaft position sensor electrical connector. Disconnect the coolant hoses and position to one side. Unscrew (3)bolts and remove the thermostat housing.
Mar 07, 2011 | 1999 Ford Contour
I am getting two codes p0193 and p0340 how do I fix this
these are not ford code numbers so refer to autozone where you had it checked ,they charged you for an incomplete job ,they should supply the information
Dec 08, 2009 | 2000 Ford Contour
Where is the camshaft position sensor located on a 1999 ford contour?
what is your engine size?? give me the eighth vin number starting from left to right..then i will be able to help you..
May 16, 2009 | 1999 Ford Contour
Where is the camshaft position sensor in a 2000 ford contour
should be on the rear of the right side of the head
Apr 27, 2009 | 2000 Ford Contour
Vehicle Parts & Accessories Logo
103 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
