Question about Sony Ericsson K750
The camera shutter is always open
Recently my k750 goes to camera mode by itself even the shutter was closed. I tried open/close but it keeps getting into camera mode. One it drains my battery quickly and secondly it is making pretty difficult to use in normal phone mode (could get back in phone mode for only brief time). Plz help.
Plecs can you send me k750i Camera solution (with photos)
Posted on Dec 27, 2008
My samsung BL103 camera takes good pics inside but ot outside. how do i fix
First make sure that you are in "Automatic" mode, and not in one of the camera's othe manual modes which may keep the shutter open for an extended period. But if you are indeed in auto mode, and it's still doing this, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 09, 2011 | Samsung BL103 Digital Camera
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
Shutter will not open every time i take a photo. The photo always comes out black on the view finder
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 27, 2011 | Cameras
My D60 has recently started having a long delay after snapping a photo. I can hear the shutter open -- stay open -- then close. The images are, of course, blurry and awful. I didn't change any settings, so...
Hi Angela, check to see that your MODE dial is still set to AUTO or PROGRAM MODE or a SCENE Mode. Almost sounds like the camera is set in the "S" Mode which is Shutter Speed.
Hope this helps!
Feb 24, 2011 | Nikon D60 Digital Camera
Hi, I would like to take a timed exposer, maybe for as long as five minutes......Thanks
In manual exposure mode, set the shutter speed to bulb. This is the next slower shutter speed past thirty seconds. The bulb setting will keep the shutter open as long as you keep the shutter button pressed.
It's easier if you have a remote control. With the ML-L3 wireless remote, you can press the button once to open the shutter and again to close it. Most wired remotes have a lock so you can lock the shutter open until you want to close it.
Nov 24, 2010 | Nikon D70s Digital Camera
Hello i have a problem with my canon powershot A1000Is digital camera. When i open the cam it only shows black screen and when i`m trying to take a picture is also black even if i check it on the computer...
Nov 20, 2010 | Canon Powershot A1000IS Digital Camera
The Screen always shows black and it takes all black pictures
Sep 07, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
LCD screen is blank and pictures are also blank
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
Flash won't open on the d40
The flash on D series doesn't always open by itself or when you push the button, as part of the design. If you are in manual mode the flash should open when you push the button, but when in Auto, if there is enough light present for the flash to stay closed, even if you push the flash button, I don't think it will open.
In Auto mode, try pointing the camera at something dark or holding your hand up in front of it and push the shutter button halfway down to see if the flash opens. If not, you will probably have to take it in to be repaired.
Sep 26, 2007 | Nikon D50 Digital Camera
Sony Ericsson K750 Logo
78 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
