Question about Pool & Spa
I have a pool pump, model s55cxplf-7637, that I need bushings for. Where can I get them?
New polygroup 2000 gph pump is loud
firstly, don't be so certain that doubling your pumping capacity isn't damaging other parts of your pool system. Excessive flow reduces filter efficiency, can cause hyper chlorination, and cause faster degradation of the plumbing and pool surfaces.
a noisy pump typically indicates poor lubrication on bearings and bushings in the pump assembly, or misalignment of those parts. Things like this happen.
Either replace the pump (and i recommend going back to the original design specs) or rebuild it, using new bushings / bearings, high quality lubrication, and be certain that the drive shaft is perfectly straight, and that the bushings allow it to spin freely.
Jul 04, 2014 | summer escapes Polygroup Quick Set...
What causes a pool pump motor to overheat
Blocked or clogged water input line
Sucking air from a leak, not enough water thru system
Excessive debris in strainer baskets
Filter needs to be backwashed
Filter needs new sand or new cartridge
Filter needs to be taken apart and "fingers" cleaned
Filter Pump Impeller is obstructed
Filter motor is in-correctly wired
Filter motor bushings need replacement
Filter motor bearings are worn
Filter motor is "shot"
Apr 16, 2013 | Emerson Pool & Spa
S55CXPLF-7637
buenas noches
tengo una bomba de este modelo, quisiera saber como se conecta, ya que tiene 4 cables y no se como van
Sep 24, 2011 | Emerson Pool & Spa
Electric hvac blower fan motor turns freely when off but when on seems to be electromagnetically held in place (cannot be rotated by hand).
THE BUSHINGS ARE BAD,SO THE ROTOR SHAFT IS DAMAGED, THERE IS NO FIXING THESE. BUY A NEW MOTOR, AND OIL IT EVERY YEAR. YOU CAN 20-30 YEARS OUT OF ONE IF YA KEEP IT CLEAN AND OILED
Dec 31, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I need to replace my out put seal on my hot tub pump. i need help getting the impropell off the motor shaft?
Take the pump to a motor shop. there is often shaft damage...and then bearing and bushing damage...
Oct 19, 2010 | Waterway Pump Part Seal Set Ps1000 Cd 319...
My drain hole is stripped on my hayward pool pump. the threads are completely gone as i was trying to put a metal fitting in the hole for the use of an ozone generator. can i re thread the hole? it is a...
There are a couple of ways to do this repair, First way is to buy a reducer bushing (threads on the inside and smooth surface on the outside), drill out the hole to tightly fit the bushing, and prime and glue it in place. The second way is to buy a tap (the next size up), buy a brass reduser bushing with threads on both the inside and outside. If you dont have enough material to inxdease thr hole size, then you will need to buy some J.B. weld and fill the hole, wait 16 to 25 hours to drill and tap
Jun 14, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
250 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
