Question about HP Office Equipment & Supplies
HOW DO YOU REPLACE THE FORMATTER BOARD ON A HP4200
REPLACE FORMATTER BOARD
2 Suggested Answers
  • 8 Answers
SOURCE: how to replace a formatter
i don't know if can be any shortcuts to print the configuration if the formatter doesn't work properly. the configuration is stored on formatter memory. if the formatter is in good condition you may follow the menu. to change the formatter is pretty easy. you can search a manual on internet.
Posted on Jan 10, 2012
55.00.00 DC Controller error
Basically The engine is not communicating with the
formatter.
1. Turn the device off and then on.
2. Verify that the flat ribbon cable between
the ECU and the formatter PCA is
connected correctly.[do extra care while removing from board easily crack at ends]
3. If the message persists, replace the
ECU[check on board and track,component damaged-burned its fixable].
If the message still persists,replace the formatter.{before replacing it can be fixable by hot oven/hot plate method }
inquiry send on http://electronicdoctor.weebly.com
0740d731-eaf6-439f-a99c-b738dfa73141.jpg formatter
156d8d89-0eee-4c56-aad5-db018e3e9d12.jpg ecu
Apr 03, 2014 | HP LaserJet P3005n Printer
T1120ps formatter board replacement
3_7_2012_9_04_00_pm.jpgHi above formatter snap shot located at back side of left door. Unscrew both sides & pull up to remove,fix another formatter in same manner.. But how you confirmed that formatter faulty? Do you checked light pattern?..pl take experts advise before replacing the things.
Mar 06, 2012 | HP DESIGNJET T1120PS 44 Printer
HP 6210 has all new cartridges (twice) and aligns cartridges, but then prints blank pages. What's its problem?
Hello jtfehr28,
Welcome, and thank you for using FixYa!
To answer your question; your problem is the Formatter Board. This board is what controls all incoming/printable data to the printer.
I have located the replacement part for you, and listed the link below.
Formatter Board
http://www.partshere.com/online/detail.asp?partno=Q5801-FORMATTER-R
Be aware that this is a $95.00 part. You could just as easily replace the entire unit for a little more/less.
Have a great day!
Sep 11, 2011 | HP LaserJet 4 plus Printer
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
How to replace a formatter board on hp p3005 printer and is there a way you could print the printer configuration first without replacing the formatter board first?
Jul 07, 2011 | HP LaserJet P3005n Printer
Is there some printer procedure for replacing a bad formatter board on the HP Photosmart C4280 printer?
it will be a tough task to replace the formatter board but its doable. Just loosen up the screws located on the side of the printer and if you can remove the rollers , cartridges and bard, you will see the system board of it. In that way, you can replace the formatter board..
Jun 09, 2011 | HP C4280 AllInOne InkJet Printer
Hi Laserjet 1522 Formatter Issue Possible Solution!!!!
There are none. Only by replacing the formatter board will you be able to solve these issues.
Al
Sep 23, 2010 | HP LaserJet M1522nf Multifunction Printer...
HP3030 - burned LIU - how to tell if Formatter board is still OK?
First of all the LIU is a daughter card that fits onto the formatter, its only function is to enable you to send and receive faxes. The ports on the formatter allows PC to communicate to printer by USB or via network.
Try printing the configuration page if this page prints correctly then you know that engine controller and the formatter are working properly together. If it doesn't print try engine test this test excludes the formatter. If engine test good then you're looking at bad formatter, and or purchasing a new printer.
Feb 18, 2010 | HP LaserJet 3030 All-In-One Printer
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
How do I replace a formatter board on an HP 3005N. It is out of warranty and I don't want to take it to a retailer to fix. Thanks
Hi there Fairly simple process romve the right hand side cover (slide to the back of the printer and lift off) open the formatter board protection cover hindged at the back then disconnect all cables and remove the formatter board Regards AL "alstech"
Jun 15, 2009 | HP LaserJet P3005n Printer
71 people viewed this question
Seeker5211
Seeker5211
