Question about Pioneer Car Audio & Video
Have Pioneer DEH2950MP Head unit and it constantly cuts out when the Volts drop down low such as at the lights or when driving and the aircon cuts in,i have tried conecting it directly to the battery - & and putting a higher rated Voltage regulator on the alternator, but it still cuts out, the previous unit also a Pioneer radio Cassete used the same wiring loom and did not have these problems, i hope you can help.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 32 Answers
What condition is you're battery in as if that's on its way out you could experience the problem you're having. Just a thought.
Posted on Jul 17, 2017
SOURCE: Basslink keeps cutting off into protection!!
From what i have heard, If you have a speaker level input connection. this sympton does occur. You buy a scosche LOC and try giving the input to Basslink, it should work fine
Posted on Aug 18, 2008
samson-1
  • 153 Answers
SOURCE: alternator light on
The alternator is not producing any power . If it were the engine would run without the battery. Check the wiring on the alternator. It must ave an exciter wire to make it work.
Posted on Oct 07, 2008
SOURCE: amplifier does not turn on when head unit is turned on
Wow guess you dont need help sound like you need a new amp! ohhhhhh wait I changed my name and NOW DO YOU SEE HOW HARD IT IS TO GET A NEW NAME YOU HALF WITT WANNA BE ******???????/ ENJOY AND GOOD LUCK BECAUSE I TALK TO OTHER PEOPLE WITH THIS NEW NAME TO.......HOW MANY NAMES DO YOU WANT ME TO COME UP WITH. i CAN COME UP WITH ONE EVERY THIRTY MINUTES.........HOW MANY TIME YOU GONNA POST A NEW QUESTION............. OHHHHH AND DONT FORGET THE ABUSE BUTTON ON THIS ONT TOOOOO BECAUSE MY NAME ISNT ON THIS ACCOUNT EITHER JUST ANOTHER FREEEEEEE E-MAIL ACCOUNT SOOOOOOOOOOO HAVE FUN AND CRY YA HEART OUT........UNLESS IT IS THE FBI YOU CANT TOUCH THIS AS OLD SCHOOL MC HAMMER SAID.
Posted on Jan 07, 2009
  • 12 Answers
SOURCE: replaced alternator and battery still showing low/varying voltage
It soundls like you have a high powered sound system and you might have to step up to a higher amp alternator, that will give you enough power. Your battery should be fine too. Try to find out if the voltage regulator is built into the alternator and if not ask to find out where it is on the car and replace that to.
Posted on Jan 21, 2009
bunnydawg
  • 5158 Answers
SOURCE: alternator putting out 16.5volts
or and more likely... the voltage regulator either mounted on the alternator or on the wheel well is defective.
Posted on Feb 26, 2009
Why does the voltage drop to battry volts when i put the gear lever in drive?
the voltage should remain at 14.5 volts at all engine speeds above idle 13.9 volts at idle indicates that the alternator is charging but not at set voltage
head lights are the biggest drain that affects charge rate rate and it it maintains and from you description that is not a problem
when you select a gear it indicates a heavy drain which is a high resistance or a dead short in that circuit that is taking out more power than the alternator is charging
There there is nothing in the gear selection that draws such power
the other thing is that when selection a gear the engine rpm is tool low and the alternator stops charging
for auto vehicles , the idle rpm should be at 800-900 rpm dropping to 750-800 in drive
Jul 08, 2017 | Ford Cars & Trucks
WHY IS MY VOLTAGE FLUCUATING CONSTANTLY FROM 9 VOLTS UP TO 15 VOLTS????
It sounds like a loose cable that is vibration sensitive. I am not exactly following you but if it stops when the car is turned off then get the alternator and or regulator tested. Your battery should hold about 13.8v when running.
Dec 13, 2014 | 2001 Pontiac Bonneville
89 Yamaha virago 750 while riding lights go dim and engine cuts out unless bike is revved up then engine runs and light come back (sometimes) what's the problem?
You have a charging fault, it sounds like 1 phase of your alternator is down , so giving a low charge rate check in this order.
alternator winding resistance at the plug/ skt into the regulator and,or reg/ rectifier unit
the plugs clean and connections good.
next the out put voltage which should be about 13-14 volts just above idle, lights off, rev engine up to 2-3 thousand revs voltage should be 14.5volts,turn on the lights voltage should not drop to under 13 volts with the engine above 2k rpm.
low charging rates are normally down to alternator and wiring issues not the regulator which if faulty wil give no out put , so no chage at all
Jan 14, 2014 | Motorcycles
How do i set the clock on pioneer deh2950mp receiver
I couldn't find your model. You can try the following procedure. It is common for most Pioneer decks:
  1. Press and hold the SOURCE button until the unit shuts off.
  2. Press and hold SOURCE again until the clock appears.
    *With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button.
  3. Press the left or right arrow to select the segment of time you wish to adjust.
  4. Press the up or down arrows to increase or decrease the numbers in the blinking segment.
  5. Once the clock is set correctly, press the SOURCE button to exit.
Apr 23, 2011 | Car Audio & Video
I have a Pioneer GM X862 car amp, with a constant red light on it. Also, it is supplying the subs with power, they are lightly vibrating but its not pushing like it should. No bass.
Make sure your power line comes directly from the battery and that iyt has no abrasions or cuts in it. Check your ground and make sure that it has a good connection to the vehicle chasis. Ensure that the remote line is connected properly to the remote lead from your head unit/receiver.
Common mistakes in this area are using the remote turn on lead as a power lead. It does not have near enough power to drive the amp so you will only get a slight trickle of power.
Jake
Oct 02, 2010 | Pioneer GM-X862 Car Audio Amplifier
99 silverado charging problem
the problem could be a bad connection somewhere in the wiring or the voltage regulator, it should be charging between 13.8 & 14.3 volts, it should be constant not up & down.....hope this helps.....cheers
Jul 19, 2010 | 1999 Chevrolet Silverado 1500
Hi , I just brought a KD-G646 head unit and it wont play cd's at all. The radio works fine, but the usb only works if the unit is turned down. Could i have something wired wrong or is the unit faulty. It...
well, the USB problem i cant help you with, but if the cd isnt loading, theres probably something wrong with the loading mechanism, which usually means that the unit is faulty. it would be more cost efficient to buy a new head unit than to pay someone for the parts and labor to repair the one you have.
Aug 18, 2008 | JVC Car Audio & Video
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Dec 31, 2007 | DB Drive A460 Car Audio Amplifier
No sound from the amp
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up and the light stays on, the wiring needs to be checked. If it still shuts down, the amp likely has at least 1 blown output IC.
Nov 30, 2007 | Pioneer GM-X372 Car Audio Amplifier
Car Audio & Video Logo
60 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
