Question about ASUS Computers & Internet
Need a manual for p5ql-vm epu /cm5570/dp
Need a manual
2 Suggested Answers
  • 10406 Answers
SOURCE: Need Manul for ASUS SKT-775 P5QL/EPU S/L 1333 FSB
Look at the "tail' of each of the new fans.
They probably will have 2 or 3 wires going into a WHITE-coloured plastic connector. Look for 3 gold-coloured pins on the motherboard -- that will match the holes in the white connector.
The add-in video-card _should_ have a connector that fits into one of the WHITE or BROWN sockets on the motherboard, while the "spine" of the video-card fits flush on the "back" of the computer-case.
Your motherboard probably has a built-in Ethernet port -- there's probably no need to add-in a separate Ethernet card.
You probably do _NOT_ need to cite an ID/password -- just connect your Ethernet port, via an Ethernet cable, to either your router or your cable-modem or your ADSL-modem, and your computer will automatically obtain an IP-address.
Posted on Apr 05, 2010
Testimonial: "But this built in LAN card does ask for ID and Password. Strange how they set this up. No Idea were to get a manual for the board?"
Asus p5ql-cm schematic
The user manual can be found on the manufacturers site here.
https://www.asus.com/Motherboards/P5QLCM/#support
Nov 08, 2013 | Computers & Internet
Need picture layout and specs fore cg5270
http://www.ebay.com/itm/0A01-001L0AS-ASUS-ESSENTIO-CG5270-P5QL-VM-Motherboard-61-MIB8Q3-01-OEM-/221134531038?pt=Laptop_Batteries&hash=item337ca529de
[The above is for Reference, NOT advertising ]
The Asus Essential CG5270 Desktop PC uses the Asus P5QL-VM mobo.
(MOtherBOard)
http://www.asus.com/Motherboards/Intel_Socket_775/P5QLVM_EPU/
Click on the Download tab.
(Overview / Specifications / Download / etc)
Click on the blue Down Arrow, on the right side of the - Select OS box.
Click on ANY Operating System. You are just after the Manual.
At the bottom of the list click on the + sign, to the left of the blue -
Manuals (7)
Scroll the INSIDE blue scroll bar down, until you see -
Version E4576 - P5QL-VM EPU user's manual (English)
Click on the blue - Global
A small window will come up -
Opening E4576_P5QL-VM-EPU_manual.zip
Make SURE there is a Green dot, in the small circle to the left of -
Save File.
If not; left-click once in the small empty circle, to the left of -
Save File.
Now go below in the small window, and click on - OK.
A small download window will come up. Allow the file to download all the way, then DOUBLE-click right on the file name.
Another small window will come up.
Go to the far left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name.
(E4576_P5QL-VM EPU, next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
Motherboard Layout is on Page 1-6
Internal Connectors on Page 1-24
Specs on Page 1-13 for Ram Memory, and Page 1-1 for the motherboard.
A) CPU:
Supports Intel;
Core2 Duo, Core2 Quad, and Core2 Extreme processors;
with,
either an 800MegaHertz Front Side Bus, 1066MHz FSB, or 1333MHz FSB.
ALL use the Socket T processor socket. (LGA 775 = Same/same)
ALL based on -> Up To the 45nm architecture.
(Means will support Intel Core2 processors that are based on the 65nm architecture, OR 45nm architecture)
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors
The motherboard chipset is an Intel G43 -> Northbridge chip; and an Intel ICH7 -> Southbridge chip.
(Part number on Southbridge chip is Intel 82801GB)
THIS, is according to the following website,
http://www.meetgadget.com/gadget/2815/ASUS+Essentio+CG5270
I don't think so.
The Intel G43 - Northbridge chip, is usually matched up with the Intel ICH10, or ICH10R - Southbridge chip,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
Scroll down to G43 in the left column.
(Past G35 and P45)
[Part number of ICH10 and ICH10R, is Intel 82801JB, and Intel 82801JR; respectively,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Southbridge_9xx_and_3.2F4_Series_chipsets ]
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
http://en.wikipedia.org/wiki/Northbridge_%28computing%29
However, suggest you use the free tiny program CPU-Z, from CPUID.com, and find out what motherboard chipset is used,
http://www.cpuid.com/softwares/cpu-z.html
[ When CPU-Z is opened it automatically opens to the CPU tab.
(Processor)
Clicking on the Mainboard tab gives you information on the Motherboard.
If you need help in downloading, installing, or using CPU-Z, post back in a Comment ]
B) Ram Memory:
DDR2 Sdram.
240 gold plated contact pins. 120 on each side.
One Locating Notch.
Reputed to use 800MegaHertz up to 1333MHz.
(800MHz, 1066Mhz, and 1333Mhz)
However it MATTERS on what Processor you are using.
Ram Memory typically operates at half of the Frequency Rate ('Speed'), of the Processor's Front Side Bus. (FSB)
Since the Intel G43 came out in 2008, it stands to reason that the PCI Express technology is PCI Express 2.0
http://en.wikipedia.org/wiki/PCI_Express#PCI_Express_2.0
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 31, 2012 | ASUS Computers & Internet
Need manual for model cm5570
Donwload the manual from ASUS Support: http://support.asus.com/download/download.aspx?modelname=CM5570&SLanguage=en-us
Dec 31, 2010 | ASUS Essentio Desktop with Intel Core 2...
Hello there. I have a problem with my motherboard ASUS P5QL/EPU, when i turn on my pc, its turn of and restart, when restart, its make a 3 beeps sound and not present nothing else. Its never begin the...
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 23, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
Apr 05, 2010 | Computers & Internet
P5QL motherboard beeps, no video
This usually happens when there is poor connectivity between RAM and the DIMM slot. Power off the system ans unplug it from the power. Remove the static from hand. Try removing the RAM modules one by one, clean the slots and RAM contacts and reinsert it back. (No moisture please)
Power on the PC. I believe it will get resolved.
Please come back and rate my solution if this really turns helpful for you or also if you need more clarification. Thnx
Apr 03, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
No signal to monitor.
try to put a pci-e video card series 9600 geforce or ati
Mar 03, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
SATA drive takes too long to boot up
Is the SATA drive connected to the first socket? Also, if the old IDE drive is not used, then disable their use in the bios - don't use the AUTO function.
Jan 31, 2010 | ASUS SKT-775 P5QL/EPU S/L 1333FSB...
Specify a suitable board for intel quad core 2.66
Obviously the p5q-vm is a better mobo as it has a faster FSB and supports up to 16G of RAm vs 4G on the p5ql-cm.  If you are looking for a gaming PC then certainly the p5q-vm is the better choice.  With that said, you may also want to consider another video card.  While the 9600GT is a fantastic card, it will soon be on the bottom of the dogpile when it comes to gaming.
Apr 24, 2009 | ASUS P5PE-VM Motherboard
Power switch & reset switch hookup
This should be your manual:
http://dlcdnet.asus.com/pub/ASUS/mb/socketAM2/M2A-VM/e2975_m2a-vm.pdf
Page 1-32 Has your connections.
Hope this helps :)
Mar 08, 2009 | ASUS M2N-MX Motherboard
Computers & Internet Logo
215 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
