Question about Dyson Ball DC24 Bagless Upright Vacuum
Removing the hose - Dyson Ball DC24 Bagless Upright Vacuum
  • Official Brand Answer
  • 2,572 Answers
Hi Carol,
I'm not sure from your question whether you want to remove the hose from the machine to use it, or to replace it. For a step-by-step guide on using the hose, wand and accessories, please visit our Support page for this machine:
http://support.dyson.co.uk/support/dc24/dc24-multi-floor/maintaining-your-dyson-machine/how-to-use-accessories/how-to-use-the-combination-tool-step-1
To remove the hose from the machine in order to replace it, this guide may be useful:
http://support.dyson.co.uk/support/dc24/dc24-multi-floor/how-to-use-your-dyson-vacuum/how-to-remove-a-blockage/removing-blockage-from-wand-and-hose-step-1
I hope this helps - if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 24, 2012
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
Aug 08, 2016 | Riccar Vacuums
How to remove hose to replace it
Pull the wand out and remove from hose. There is a tab holding the hose on at the bottom. Release the tab to remove the hose.
Jul 30, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
How to remove a clog
Hey there! Most of our vacuums you are able to remove the tool hose without the use of a screwdriver or other tools. Follow these brief steps to check your vacuum for clogs.
Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
Remove the hood or nozzle to access the brushes, remove the brushes. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
Hope this helps you!
Jun 01, 2014 | Hoover Vacuums
How do i use the hose on featherlite bagless
Hello! To use the hose on your Featherlight follow these simple steps below.
· Cleaner must be in its upright position. Remove lower hose from the side of the cleaner by twisting to the right and then pull off.
· Remove the hose from the tool caddy.
· Slide the tool hose into the lower dirt hose with the notch facing up. Push together and twist to secure.
· Choose any of the handy accessories or use the hose alone. Simply push the attachment firmly onto the end of the wand or hose handle. To remove tool, twist and pull apart gently.
I have also included a link to the instruction manual if needed. Hope this was helpful!
http://dirtdevil.com/file/661/
May 17, 2014 | Dirt Devil Featherlite Bagless Vacuum...
How can i remove the dust from vacum hose?
If you can take it apart and remove the hose then I would flush it with a hose with a nozzle. I would also spray the inside of the hose with an all purpose spray.
Jul 21, 2012 | Bissell Vacuums
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
I am experiencing some (not complete) loss of sunction when I use the hose
Possibilities:
Dirty filter, needs cleaned or replaced.
Partially clogged hose, needs cleared. Detach hose from tank and drop marble down the end of the hose. It should roll through the hose and power head to the floor.
Partial clog in the power head between where hose attaches and the brush. Detach hose from power head and drop marble into opening. If the marble doesn't roll through, there's a clog that needs removed. You may need to disassemble the power head to do so.
Leaky hose, needs replaced.
Clog between back of tank and filter. This is where the hose attaches to the tank. Remove clog.
Clogged filter at bottom of tank, needs cleaned. Remove tank. There's a screen at the bottom of the tank/vacuum. Simply remove/clean anything that may be covering/clogging any of the holes.
Dec 18, 2010 | Dyson DC15 All Floors - The Ball Bagless...
I have an Aerus Guardian canister vacuum with a clogged hose. The tiny stuffed animal toy is lodged right below where the swivel handle meets the hose. Switching the air flow does not dislodge it. I would...
Consider this. If your vacuum is still under warranty, removing the hose will void the warranty on the hose. I strongly recommend calling an authorized dealer/consultant.
Although it may seem to be fairly simple to remove the handle, there are wires that need to be disconnected in order to separate the handle from the hose, gaining access to the toy. And reconnected. If not properly done, attempting this may lead to needing to purchase a new hose.
Apr 19, 2010 | Electrolux Guardian Bagged Canister Vacuum
Clogged hose...
Hi!
Low suction, poor pickup, or no suction may be due to a clog in the vacuum cleaner. If you notice a change in the sound of the motor or a reduction in the spinning action in the Dirt Container, check for clogs. Unplug cleaner from electrical outlet. Empty Dirt Container. Check Upper Tank and Louvers for build up or clogs. Check to make sure Louvers are installed correctly. To unlock the Louvers, grasp the rim and turn toward the left. Pull straight down to remove. If the Louvers are missing or not locked into place, check and clear the tube in the center of the Dirt Container. Remove the Twist ‘n Snap Hose from the vacuum by turning to the left. Check the Suction Inlet, Hose and Hose Wand for clogs. Remove any clogs from the hose using a long, narrow object. Check the Foot Hose for clogs. If needed, remove the screw attaching the Hose Wand Base to the vacuum. Straighten the Foot Hose and unclog with a long, narrow object. If the clog persists, then check the Rotating Floor Brush the Air Passageway for obstructions.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 10, 2009 | Bissell 6594 PowerForce Bagless Upright...
Ive got a sock in the tube
remove dust bin from hover and remove handle from hose then remove hose from hover and push a peice of doul up hose to remove sock and rebuild hover or buy new hose hope this helps
Nov 26, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Ball DC24 Bagless Upright Vacuum Logo
665 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
