Question about Gigabyte Computers & Internet
A friend and I built our own system - seems to be working fine - no beeps or error messages until we attempt to load windows XP. The specs are: cpu - Q6600 memory -DDR3 1333 - 4 gig motherboard Gigabyte ep45t-ds3r 500 gig seagate sata hardrive HD4870 512MB GPU Xp seems to load up to the blue screen then crashes to two error codes: pci.sys.f748eovf base@f748700.datestamp 3b7d855c & ox0000007e (oxc0000005,oxf748eoef, 10xf78ea208, oxf78df08) I'm attempting to load Xp home, we think it might be the drivers not recognising the sata drive but we're just guessing...
    Genius:
  • Gigabyte Master
  • 1,250 Answers
Change RAM then try
Posted on Oct 28, 2008
Major memory reference error
The memory could not be read message indicates to me that you may be experiencing a problem with your RAM. Test it doing this Test your RAM with Windows Memory Diagnostic tool
Feb 27, 2017 | Fujitsu Siemens Amilo Pro V3515 Laptop...
Plug & Play recognises Dub E-100 attached and device manager lists it however continually get error 39 driver missing or corrupt. Drivers loaded directly from CD supplied / also download version...
Hi.Try to install again your windows xp.need fresh windows xp installation because same of your operating system software device corrupted and missing.to recognizes that USB network adapter gadget.
Jun 09, 2011 | D-Link DUB-E100 (DBDUBE100) USB Network...
Blue screen of death. unable to download drivers. can not get to safe mode. cannot reload orperating system disks.
First off, note down all relevant information when you see a BSOD flash across the screen. This includes the error number and friendly name from the 'bugcheck' section of the stop error (see above), and any file names specified in the 'driver information' section.
If the BSOD comes up on the screen for a split-second before the PC restarts and wipes all the useful information away, we need to change some settings within WinXP. In most cases, it should be possible to stop your PC from automatically restarting when it develops a major error, allowing you enough time to jot down the BSOD error message. If you are using WindowsXP, right click on my computer > Properties > Select the 'Advanced' tab > and under 'startup and recovery' click the 'settings' button. This will open a new window, and under the 'System Failure' heading, uncheck 'Automatically restart.' Continuing on, attempt to restart the computer normally into Windows. If the BSOD occurred while booting Windows, you may be taken to a troubleshooting menu and will have to select 'attempt to start Windows normally.' If your computer starts correctly, continue using it and store the error information for later reference. If the BSOD reoccurs at random or irregular periods, see Section D below on troubleshooting intermittent stop errors.
If your system does not start correctly or the stop message happens again, reboot the system. When the POST (memory checking) screen comes up, press F8 repeatedly. This will bring you to the Windows advanced options menu.
In the Windows advanced options menu choose 'safe mode' to attempt to boot into Windows Safe mode. Safe mode loads Windows XP with a minimal set of drivers and no automatically loaded software. If faulty software or drivers are causing your BSOD problem, safe mode should load correctly. If safe mode loads correctly, refer to Section A below on 'troubleshooting software stop messages.'
If safe mode does not load correctly, and/or you get the same stop message upon attempting safe mode, it's time to try the 'restore last known good configuration' option in the advanced options menu.
Restart your computer, pressing 'F8' again to load the advanced options menu and select 'last known good configuration (your most recent settings that worked).' This uses Windows XP's built in system restore utility to restore the most recent save point, which should be the last time you installed any drivers or other software. If your system boots normally after this operation, hopefully your problem has been fixed.
If you are still receiving a Blue Screen Of Death after the above procedures, or if system restore was disabled on your system, note down any new information on the error and start thinking. Did you install any new hardware or software just before this problem occurred? The driver information section of the BSOD may help with this.
If you did install new hardware or software, and you think you know what it might be that is causing the problem, this gives you a big boost in resolving the situation.
Otherwise, proceed to the advanced troubleshooting sections below. Chances are your error is hardware or system file based and will require more effort to repair.
Specific Repair Instructions
If you have a reoccurring Blue Screen Of Death or crashing problem, and can't use Windows effectively because of it, it's time to look at more specific methods of troubleshooting your problem. Depending on the results of the basic troubleshooting steps above, you should have a good idea of whether the problem that is causing the stop messages is related to software or drivers you have installed, or is a hardware or system file issue.
Essentially, if you can't boot into Windows XP safe mode because of crashes or Blue Screens Of Death, you likely either have a hardware error or one or more essential system files is corrupted or missing. If you can boot into Windows XP safe mode, but get constant or frequent BSOD's when running XP normally, you have a software or device driver problem.
Make sure that if you added any RAM to your computer which is a common cause for BSOD that you added the correct RAM for your computer and that it is equally distributed in the ports meaning each port for the RAM has the equal amount of RAM on each side (eg, one stick 1GB, and the other has 1GB, etc).
Jan 03, 2010 | Dell Dimension 2400 PC Desktop
Error loading operating system - Windows Xp
If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Or Use a Windows Media Center Edition Version
Nov 18, 2009 | Acer Computer AOA150 Notebook
Windows is resuming message
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
You can try this first before the XP repair :
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
Nov 04, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Unable to reboot CPU
when its powering on let it get a little ways in then hold the power on off button until it just shuts off. Then boot it on and see if it gives you a safe boot option if it does select it. Then do a system restore to before this problem started. Hopefully this will restore the drivers.
Jan 16, 2009 | Dell XPS 200 PC Desktop
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Installation failure
I have already started to answer on the original thread!, let's keep the conversation in one place.
Oct 08, 2008 | Computers & Internet
Can u help me?
You may insert the Windows XP CD and reinstall Windows XP just to be sure. Follow the instructions on your screen and format the C Drive. Make sure you install all the required drivers to make everything work.
If you are optimistic follow the following instructions:
This will help you attempt to repair your system (and not via the Recovery Console).
Insert the Windows XP CD and follow the instructions on your screen.
Then after a certain point, you will be asked for three options --
1. Install Windows
2. Repair via Recovery Console
3. Some other option I don't recall.
Select the first option.
Then again, follow the instructions on your screen and again the computer will ask you three options.
This time select the second one -- Attempt to repair the computer (Press R).
This should start the automated repair process. This has been observed to work most of the time, but in a few rare cases it doesn't work. So I suggest you try it if you have the patience. ;-)
Good Luck.
Oct 13, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Computers & Internet Logo
105 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
