Question about Heidelberg S2000 Flatbed Scanner
ChromaGraph S-2000 Linotype-Hell Scanner
This is a large format scanner used for pre-press. Error message says e550 too few Light, Check hardware. Any guesses
2 Suggested Answers
shlummshlumm
SOURCE: will a Linotype Hell Ultra 2 Saphir run on a pC?
Yes. Just got mine running on Windows ME. Problem is getting the SCSI set up. Once you get that done, I used Vuescan (http://www.hamrick.com/) and it works. Slow, but functional. I have yet to get scans of the full scanner screen (10 x 14 inches). But 8 x 10 is working fine.
Posted on Apr 02, 2010
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Ricoh MF Copier, destination list cannot be used now, using ldap,
When it say the list can not be used, it means the hard drive/disk thet keeps your addresses have failed. The fast way would be to format the hard drive/disk and re-program your info. This commonly happens when the hard drive/disk is active during a power surge/failure or incorrect shut down. Go to service mode by pressing yellow button then 107 then hold the red/stop button for more than 5 seconds, when the screen changes press the first option on the screen(should be copy or system), now press 5832 (HD format) and enter/execute, when "completed" is displayed switch off and on. Now open your internet browser on PC, take out the web address and input your printer IP and press enter, username-admin, no password, on the left of the screen click on address book, now go to add, input all you info and press ok, now log out on the top right of the screen and test scanner.
May 01, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
After printer is on for a few minutes, getting error message-scanner failure turn printer off then on again. I am able to print before the error message appears, however, unable to copy or fax. Thank...
Solution one: Check the scanner light
  1. Follow these steps to check the scanner light by making a color copy of any document.
  2. Load plain white, unused, letter size paper in the paper tray.
  3. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  4. Make a color copy.
  5. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely.
The scanner light should be visible under the scanner glass to the right or left.
Solution two: Check the power connection
Follow these steps to troubleshoot the power connection.
  1. Press the Power button to turn off the product.
  2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
  3. Press the Power button to turn on the product.
  4. Load plain white, unused, letter size paper in the paper tray.
  5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  6. Try again to make a color copy.
  7. Press the Power button to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
  8. Press the Power button to turn on the product.
Try again to make a color copy.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists we have to reset the printer. Doing reset in the beginning stage is not recommended. Reply me back and i will provide the reset step instruction.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet D135 All-In-One InkJet...
Paper jam message is showing but nothing is jammed in scanner and it will not pull the paper through
Hi
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above info is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
Tech Satya
May 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
Oct 29, 2009 | Nikon LS 2000 Film Scanner
While the engine is running I use a scanner to
HI PRE 2000 VOLVOS CAN ONLY BE READ BY DEALER MACHINES SORRY
Oct 18, 2009 | 1999 Dodge Intrepid
Will a Linotype Hell Ultra 2 Saphir run on a pC?
Sep 10, 2009 | Heidelberg Linocolor Saphir Ultra2 Flatbed...
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
I need a scanner that will scan 10X14 pictures
I found some scanners for you listed below but,
You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
This is what most people do rather than buy a very expensive large format scanner.
Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
Though copy stores may have the size you need, copywrite issues will be asked about.
Here is the list.
large format scanners http://www.microtekusa.com/lf.html
Microtek ScanMaker 9800XL Scanner
Price: $1,038.31, 12-by-17-inch tabloid size bed
Mustek Scan Express A3 1200 Pro USB Large Format Scanner
$154.69media_size_maximum: A3 (11.7 in x 16.5 in)
http://www.contex.com/english/scanners/sd_series_scanners.aspx
Maximum Scan Width 44in.
http://www.xerox.com/digital-printing/large-format-printers/large-format-scanners/enus.html
Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
Thank you and good luck.
Oct 25, 2008 | HP Computers & Internet
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
326 people viewed this question
Top Heidelberg Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
