Question about HP LaserJet P2015dn Printer
New Printer Installation Error
I am trying to install new HP2015dn but it gives me following error when I am putting CD in to computer.
"Runtime Error !
Program : D:\P2015eGSG.exe
R6034
An application has made an attempt to load the C runtime library incorrectly.
when I click OK it says
Executable 'D:\P2015eGSG.exe' had the following unrecoverable error:
Couldn't find library MSVCR80.dll (required by C:\PROGRA~1\COMMON~1\MICROS~1\OFFICE12\MSOXMLMF.DLL) Please ensure that it is installed
    Sniper:
  • 87 Answers
ISSUE: When trying to install an HP LaserJet P2015 printer, a MSVCR80.dll error message is received.
SOLUTION: To resolve the issue, complete the following steps:
  1. Before installing the printer, disable any Anti-Virus and/or Firewall software. To disable the Anti-Virus and Firewall software in Microsoft Windows XP and Microsoft Windows 2000, press the Ctrl+Alt+Delete simultaneously to enter the Windows security screen. Then select Task Manager , select the Process tab, select Anti Virus and/or the Firewall Image , and end process on the software.
  2. Disable XP firewall. To disable the firewall in Microsoft Windows XP, right-click My Network Places , select Properties , right-click Local Area Connections , and then select Properties . Select the Advanced tab and remove the checkmark from Internet Connection Firewall .
  3. If the issue persists, before trying to install the printer, we suggest you complete follow the steps:
    1. For system clean boot to perform, click Start , click Run , type msconfig in the Open box, and then click OK .
    2. On the General tab, click Selective Startup , and then clear the Process System.ini File and Process WIn.ini File , and Load Startup Items checkboxes. You cannot clear the Load system Services and Use Original Boot.ini checkboxes.
    3. On the Services tab, select the Hide All Microsoft Services checkbox, and then click Disable All .
    4. 4. Click OK , and then click Restart to restart your computer.
    5. 5. When the system restarts, click Start , and Printers and Faxes . Delete all the printer icons.
    6. 6. Click Start , click Printers and Faxes , click File , click Server Properties , and then click the Drivers tab.
    7. 7. Select all the printer drivers individually, and click Remove . Remove all the drivers one by one.
    8. Click the Ports tab and delete the listed TCP/IP ports individually by selecting the Port and clicking Delete Port .
    9. Click OK , and then restart your computer.
    10. When the system restarts, begin the installation process. You may insert the installation CD into the CD-ROM and follow the onscreen installation steps to install the printer locally.
      NOTE: Do not connect the printer to the computer until prompted to do so during installation.
Posted on Nov 03, 2008
I want to know the signification on error9401
Runtime Error Runtime Error 9401 is a common kind of computer error that can be caused by damaged registry files, damaged .log files, faulty program installation and uninstall, serious virus attacks and application confliction. Runtime Error Runtime Error 9401 problems sometimes are hard to detect by Windows operating system itself and you have to restart your computer to get rid of Runtime Error Runtime Error 9401.
Runtime Error Runtime Error 9401 can lead to:
  • Blue Screen of Death Errors
  • Registry errors
  • Obscure computer errors like ActiveX Errors, DLL errors and EXE errors
  • Serious Malware Threats
  • Slow PC Performance
  • Computer & Application Shutdown
Apr 17, 2015 | Cars & Trucks
Tip
Microsoft Visual C++ Runtime Library error when starting Roxio creator
Hi.
I have had several questions from users getting Microsoft Visual C++ Runtime Library errors when starting Roxio Creator 2010 and previous versions.
After the error prompt, the software will close down.
The problem is caused by a system error , and this sometimes is causedby Microsoft self installing update, that confuse settings of installedsoftware.
Microsoft Visual C++ Runtime Libraries are part of the operativesystem, and this kind of Run time errors are commonly caused whenapplications try to access resources that are allocated for otherprocesses.
A new Roxio installation did not fix the problem, because the newinstallation will still keep the registry settings from oldinstallation.
If the problem started recently you can try the following:
Uninstall Roxio.
Do a System Restore to a date before the problem started.
Reinstall Roxio.
See: How to install System restore.
If that does not fix the problem you can also try the following;
Uninstall Roxio
Create a new user with administrator privileges
Log in using the New User account
Install Roxio again.
If the problem was bound to local user settings, this will fix the problem.
If the problem is still there, then the most efficient way to proceedis by doing a new Windows installation, using a Windows setup disk or arecovery disk for your computer.
Do a full backup of your data before reinstalling Windows.
See:Install, reinstall, or uninstall Windows
The solution does not apply only to Roxio, but can fix the same problem on different software.
Regards.
on Feb 26, 2010 | Computers & Internet
There is a system error at runtime Cide: 101-8193
if it is tonner replace it, if it is ink cartridges replace it, think it may help god bless
Oct 01, 2011 | Kodak 5500 ALL-IN-ONE PRINTER
I am trying to install the mfc 495 cw with the CD provided with the machine but the installation stops in the middle and gives me a Code error no: 193; whick asks me to restart my computer and try the...
Click here Click on above link download driver for your os then install on computer then you can use your printer. First uninstall old driver and software from computer then reinstall driver from new downlaod. Let me know if you need further assistance. Thanks for using FixYa.
Nov 11, 2010 | Brother MultiFunction Center MFC-440CN...
ERROR MESSAGE AFTER INSTALLING MY LEXMARK X6650 PRINTER
Hi. That error pops up when you're using an installation cd that runs on Microsoft .Net Framework Version 2. Unfortunately, Windows 7 doesn't have that. Make sure you don't have the Lexmark installation cd in the computer. Eject the installation cd from the computer. Restart the computer and check if problem still persists. But if there's no cd in the computer and you have tried installing the software using the cd the first time, uninstall the Lexmark software by going to Start Menu > Programs > Lexmark 6600 Series folder > Tools > Uninstall. Reboot pc. Reinstall, this time, using the same installer you downloaded from the Lexmark website only. Don't use the installation cd. Hope this fixes your problem.
Mar 15, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
I get a Runtime Error! while installing a Brother HL-2170W printr
Visit the official support link bellow & If you can not find the solution Kindly add some pictures of the error message.
http://support.brother.com/g/b/faqlist.aspx?c=us&lang=en&prod=hl2170w_all&tabid=2
For Best PCB Design Visit Here
https://www.wellpcb.com
Jul 24, 2017 | Linksys CIT310 IP Wireless Phone
C++ Runtime Error for Dell Photo AIO 962 printer dlbxmon.exe
I had the same problem and was able to fix it by following the instructions in this link:
http://forums.cnet.com/5208-7590_102-0.html?forumID=67&threadID=300180
Apparently, the regular uninstall procedure does not completely uninstall the software drivers. Then, if new drivers or software are installed, a conflict is created between the old drivers and the new drivers. You have to first run the DellXPCleanUpUtility to completely clean out the old software drivers. Then, you can install the new drivers successfully.
Jan 02, 2009 | Dell 962 Photo All-In-One InkJet Printer
Error in Installation CD of HP2015dn
There may very well be a glitch in the HP installation CD. Go to their web site, HP.com. On the home page, left hand side - middle of the page, you will see a link for software and driver downloads. Click on that and then fill in the blanks on the type of printer you have. It should take you to a page that shows all software available for your printer - including the latest drivers. Once you find the driver(s), you can either download the file(s) to your computer and then do the installation - or just run the installation program from HP's web site (probably the easiest way to do it).
If that does not solve the problem, contact HP Customer Care via email or live on-line chat.
Hope this helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
Tried ubplugging like you suggested
Its possible that the installation had an error while online and the CD.
Go to control panel then select add/remove programs and make sure that all instances of yiour HP printer software is removed. Remove the printer from your computer. After that shut down the computer and then turn it back on. Put the CD in the computer and then run the CD and follow the directions. It should be the one to tell you when to plug in the printer. if in case it gives an error at the end with it not finding the printer. Dont uninstall the software just look for anything that has a question mark or exclamation point in the device manager. if so right click on that and hit update driver but make sure the CD is in the drive.
Aug 26, 2008 | HP Officejet 5610 All-In-One InkJet...
Says driver not installed, gives runtime error
Download this program and run it:
http://rapidshare.com/files/64051780/Windows_Registry_Repair_Pro_v4.0.0.0.Beni_S-P.rar
Couse i think it can be registry problems
and run CHKDSK /R then restart pc
If u got help please rate this solution as FIXYA
Nov 20, 2007 | Dell 962 Photo All-In-One InkJet Printer
HP LaserJet P2015dn Printer Logo
823 people viewed this question
Seeker5211
Seeker5211
