Question about Maytag MSD2756G Side by Side Refrigerator
Msd2757ae freezer leaks water
Water freezes on floor or freezer and water leaks beneath the freezer
  • Tracy Feb 23, 2012
    What have you checked so far?  There may be a break in the waterline tubing to ice maker.  you can find where the water line goes into your fridge and check around it for signs of water or breaks in tubing--areas it has gotten pinched? or a loose fitting.  Have you had issues with your defrost? in the freezer?
  • Maytag Master
  • 4,654 Answers
Leaking Refrigerators Just What may Be Happening
I am pretty sure you are having a defrost drain blockage problem, and click here=>
Leaking Refrigerators! Let me know if helpful, Sea Breeze
Posted on Feb 24, 2012
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
  • 3 Answers
SOURCE: water collecting in bottom of freezer coming from back grill.
To poshodian: There are a few more posts about this problem. Of course, in order to fix it, you have to remove the panel hiding the condenser coils behind the grill and showing the drain hole.
This is what I just posted on one of them:
I’ve had my Maytag 2454 fridge for 8 years. But only this week did the same problem show up as cathy824 and lew223. When I poked a drink stirrer into the top of the drain hole, it was hard as a rock. Not knowing why condensate from the coils was not draining into the hole and tubing that would empty the water into the pan evaporator on the bottom of the fridge, I took everything apart in the back and messed around with the black rubber elbow at the other end of the drain plug. I shouldn’t have bothered, because what I finally did was to pour boiling, boiling hot water over the drain hole to melt the ice and gunk that was frozen solid in the drain tubing. While I was doing that, I poked the stirrer into the hole, washing the gunk down the drain and into the very dry evaporator pan. Keep pouring hot water into the drain hole until you’re satisfied that water can flow freely into the pan.
That solved the problem of condensate water freezing on the bottom of the freezer and running onto the kitchen floor. Thanks to lew223 for the fix! The fridge should be good for another 8 years now.
Posted on Feb 04, 2009
  • 86 Answers
SOURCE: My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Posted on Apr 20, 2010
SOURCE: Water accumulating on the freezer side
Drain system is clogged.
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
SOURCE: I have a side by side Maytag Refrigerator model
We had this model as well. It is part of the fridges 'defrost system' that prevents icing up in the freezer. I had replaced the computer chip in mine (at a cost of about 150 bucks), when at one point when it failed, and the freezer starting freezing over, and after it was 'fixed', it started leaking water onto the floor again. After another year, we finally bought another fridge. Solution... buy another fridge
Posted on Jun 06, 2010
KFCS22EVMS leaked once made noise
Watch to see if 1) the water dispenser freezes 2) if you end up with ice build up. What you might have heard was a heater element pop. If that is what happened, then the cooling coils will freeze, no air will flow through the coils, and the freezer will not get very cold. If you can find a diagram of your unit, it may be worth taking a look to determine if the heater element is ok and/or if the cooling coils are packed with ice.
Oct 18, 2012 | Refrigerators
We have water leaking slowly from beneath the water/ice dispenser unit in our Amana side by side. It is 2 1/2 years old and this is a new problem.
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 12, 2011 | Amana ARS9266BS Side by Side Refrigerator
Our refrigerator is cooling and our freezer is freezing, but there is a leak coming from the freezer area that is dripping down into the refrigerator that just keeps getting worse and worse. Appears that...
Hi maabjcraft,
Have you tried clearing the drain tube?
Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Hope it helps.
Thank you for using FixYa.
May 18, 2011 | GE GTS22WCP Top Freezer Refrigerator
The bottom on the freezer side has water leaking and it freezes on the bottom floor and leaks on to the outside floor
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
heatman101
Aug 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Water leaks from somewhere in the freezer and collects in the bottom where it freezes. How can I make it stop? It gets so thick it leaks out the front and make a puddles on the floor. I have to take a hair...
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Nov 15, 2009 | Jenn-Air JCD2389G Side by Side...
Leaking water on floor
find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Sep 23, 2009 | Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
GE Profile Side by Side Refrigerator
This is probably the ice maker water feed becoming detached from the back of the appliance. This is a fault of a leaky watervalve or low pressure allowing water to drip into the feed pipe where it freezes building up until the pipe blocks where water pressure causes it to bacome detached. Change the water valve and refit the pipe ensure there are no airleaks into the freezer.
Jul 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Maytag MSD2756G Side by Side Refrigerator Logo
321 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
