Question about Health & Beauty
How do I calibrate a taylor grill model 22-23
Error message "___" on digital scale 7404. Tried to reset after I changed batteries, and got the same error code. What can I do to fix it so I can use it? Is is done for?
--- usually means that the unit cannot calibrate itself on start up. The sensor is out of range. THis could be from being dropped, or something too heavy was put on it. They cannot be reset.
Feb 22, 2018 | Taylor Health & Beauty
What is it worth if anything?
Taylor guitars are usually on the high end price wise?
they do have beginner models also like baby Taylor guitar and it's about $500 other Taylor guitars can go for $1000 +
depends on model, condition, ect...
Hope that Helps?
Mar 04, 2015 | Taylor Music
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Constant LO reading on Taylor 9200
This might be due to calibration or the thermocouple is bad. You can get new thermocouples here http://www.taylorusa.com/restaurant-hospitality/thermometers?t_type=42
They also have contact info and calibration procedures.
Jul 04, 2014 | Home
Current temperature on Taylor TruTemp 3528 reads "LLL"
It needs calibrated. LLL (low) means you need to put the probe in a glass of ice water. It will then say HHH (high) means you need to put the probe in boiling water, don't let the probe touch the sides of the metal pot of boiling water.
May 07, 2011 | Taylor Instruments Taylor TruTemp Digital...
I need to know how far to insert the probe for best cooking results. I have a Taylor 4609 model temperature prob for my grill.
Into the center of the meat you are cooking. There are minimums to which meat should be cooked to kill germs.
May 20, 2010 | Garden
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Taylor 7530 scale wont turn on,i have new batteries
Basically, the frisbee comment is on the mark. I called Taylor. a nice person walked me through a calibration exercise: take batteries out; stand on scale for 7 sec.; get off; put batteries back in (assuming they are still good); step on scale and if it reads ---- step off again, then back on to weigh yourself. My scale's display was blank, not -----, so they said calibration was unsuccessful & so I mailed it back to the NM address on the bottom. It just fits w/ padding diagonally in a USPS flat rate box. Waiting to see if they replace it (lifetime warranty).
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
Health & Beauty Logo
104 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
