Question about Toshiba 65HM167 65" Projection Television
Red blinking and solid yellow led lights. help please.
I have a Toshiba 65hm167 tv that has a solid yellow, blinking red led light. I replaced the lamp 3 months ago after the old one burned out.Then the black screen came with the led indications so purchased another lamp after calling Toshiba. I had the same problem with the new lamp. no picture just sound. any suggestions?
  • 537 Answers
SOURCE: Solid yelow led and the red led is flashing
Check your manual or:
http://www.toshiba.ca/web/pdf/5056HM66_EN.p.pdf
Use the quick restart procedure
Posted on Jul 14, 2008
SOURCE: Yellow blinking light on Toshiba 65HM167
Guest...you are not going to have any luck! If you can believe this our TV is STILL broken. And it has been since July 7th!!!! I have been fighting with Toshiba I have reported them to bbb and also to the federal trade commission. I have faxed the work order from the first time someone came out to look at it, a copy of my cell phone bill to prove the first time I called was really way back in July!! It is a main board in the tv and they keep telling me it is on "extensive backorder" Finally they offered us 3 options...a refurbished 65in, a brand new 52in LCD or a full refund in 6 weeks!! I will NEVER buy a Toshiba anything again. I suggest you call this number 1 800 351 5481. When someone picks up tell them you need to talk to Toshiba in regards to a TV, they will transfer you directly to them. The sooner you start a file with them the better because as you can see when I posted this and yes it is still broken. I have also faxed copies of everything we have been dealing with to the offices of Phillip Schoonover who is the CEO of circuit city where we bought the TV and also Atsutoshi Nishida the CEO of Toshiba. You should just ask to talk to Evette....she is the customer service supervisor who I have been dealing with. If there is anything else I can help you with please let me know....trust me I have ALL the information you will need.
Posted on Sep 21, 2008
  • 18 Answers
SOURCE: My toshiba 50HN67 TV won't power on.
I have the same TV and had the same problems. What worked for me. I tuned off the set unbluged the TV, waited about five minutes and replugged and resolved my problem. Hope this works for you.
Posted on Aug 22, 2009
vinnyq
  • 157 Answers
SOURCE: toshiba 65hm167 black screen with video input
That is correct, if the lamp was bad then you will not see a picture at all. The fact that you are getting menu means the lamp is good and most likely the processor and light engine are also okay. Check other inputs to see if you have the same problem on all the inputs.
Posted on Nov 11, 2009
  • 1039 Answers
SOURCE: I just placed a new
Is the lamp turning on?. Look in the back. If not replace the ballast.
Posted on Aug 31, 2011
Yellow blinking light on toshiba tv
http://aaaateva.com/tv-repair/tv-brands-serviced/toshiba-tv-repair/toshiba-tv-codes
the color and blink pattern of your tv led is a code that gives you the fault...check at the site above.
Jul 05, 2015 | Toshiba 65HM167 65" Projection Television
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
Yellow light blinking on tv will now come on
If you are refering to the 3 yellow blinks repeated over and over the
boot data is corrupted. Download the firmware update(link below)from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses,I used a 2 gig). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Apr 26, 2010 | Toshiba 65HM167 65" Projection Television
My Toshiba Model no. 65HM167 does not power up. The lamp light on front of t.v. flashes and thats about it. I replaced the lamp but still no go. Help.
CK the Lamp Fan if it stops running Lamp will not light and if thats ok Ballast Board it is what turns Lamp on!
Visit Encompass Parts Distrubtion for Parts List and numbers 1-800-638-3328
Mar 23, 2010 | Toshiba 65HM167 65" Projection Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
Feb 24, 2010 | Toshiba 65HM167 65" Projection Television
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Jun 22, 2009 | Toshiba 65HM167 65" Projection Television
Cant find a ballast
The ballast is actually a switch mode power supply that powers the lamp. It is an
integral part of the light engine and is not replaceable. The light engine has a price
tag of $950. If you replaced the lamp with an after market one and not the Toshiba
lamp you can experience the same problem. Some of the after market lamps will
not fire at the same voltage as the Toshiba. The blue led will come on solid and the
yellow blinking. It will try to start 8 times then give up.
Charlie
Sep 29, 2008 | Toshiba 65HM167 65" Projection Television
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 65HM167 65" Projection Television Logo
216 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
