Question about KitchenAid KSRD25FK Side by Side Refrigerator
Where is located the filter water in the fridge kitchenaid model ksrs25qgwh01
SOURCE: water filter
I don't think this model has a filter, I checked under the kickplate, no filter there.
Posted on Apr 05, 2008
  • 150 Answers
SOURCE: Kitchenaide fridge
your defrost condensate drain is clogged. kind of elaborate to explain can chat you through the fix
Posted on May 10, 2008
jumptrout51
  • 3361 Answers
SOURCE: Water Filter Output
Let me know what happens.
Posted on May 13, 2009
  • 5 Answers
SOURCE: Where is the water filter located on this model?
usually down in the bottom grille panel
Posted on May 20, 2009
  • 36 Answers
SOURCE: no water to ice maker or water dispenser
Might be a bad valve, but there are separate valves for water and ice maker. It would be unusual to have both valves burn out at the same time. Check the valves for continuity with an ohmmeter. If OK, then check for water to the appliance. The water filter is generally only for the water dispenser, so if the ice maker is out, it is not the water filter.
Posted on Mar 22, 2010
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
I have a kitchenaid ksc25inwh00 . is ther a built in filter? if so ,how do i replace or clean it?
bad model number,look in the fridge section up in the top right corner or down in the kickplate to find the filter,if not there follow the water line from behind the fridge to the end of the line,some filters are installed in the water line,check and send model number this number doesn't show up.
May 14, 2011 | KitchenAid Refrigerators
What is the model number for the water filter for the KitchenAid #KSRG25FKSS16 refrigeator and where is it found in the refrigerator? thank you.
Hello pssutherland,
I understand that you need to locate the water filter on your KitchenAid fridge. The water filter is located at the bottom of the fridge in the grill. There is a eject button that you will need to press next to the water filter in order to get it to release.
1. Press the eject button
2. pull the filter straight out
3. Remove the cap by turning it clockwise (you will need to install this on the new one)
4. Reinstall the cap on the new filter
5. Push the filter in until the eject button pops back out.
6. Purge the system run three full glass of water thru the water dispencer and throw away.
7. You are done
Thank you for choosing FixYa.com
Justin
May 11, 2011 | KitchenAid Superba Architect KSCS25INSS...
How to change water filter on model #ksbp251vss
Turn water off to frigde. Now look down at the grille at the botom of the fridge and push the bottom located to the right. The filter will come out. Take the cap off and putn it on the new one. Remove the red caps off the other end of the filter and push it in where the old one came from. Now turn water back on. your done. Good luck
Nov 25, 2009 | KitchenAid Refrigerators
Where is the water filter located on a kitchenaid ksrp25qdwh00
This particular water filter is known as a ``in line water filter`` and is located at the BOTTOM of the fridge at the LEFT hand side. located in the grill at the bottom. first you must remove the filter cap and then It simply twists out for easy replacement. part number for the water filter is 2255519. and should be replaced based on a 6 month period or the amount of water filtered. hope this helps
Thanks
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
How to remove the Pur water filter from the bottom of a KitchenAid side by side Refrigerator
It is a push-button filter located in the grille at the bottom of the fridge. Simply press the release button to remove and replace the Refrigerator Water Filter Cartridge.
Sep 15, 2009 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid KSRD25FK Side by Side Refrigerator Logo
97 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
