Question about Refrigerators
How do i reset a mafirol chiller unit as i have misplaced manual?
Can anyone direct me to an operating manual for the Brandt Wine Chiller?
Search Results
    Download brandt wine chiller manual - Google Docs
    https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for brandt wine chiller manual? Download brandt wine chiller manual.brandt wine chiller manual. User Manuals, Instructions and Guides.We have that ...
    brandt manual Refrigerators Questions & Answers - Fixya
    www.fixya.com > Forum > Tags > brandt manual
    On my Brandt wine cooler at the top is an adjustment control for temperature. ... is amanual for this refrigerator LG top mount ice box service manual Maytag ...
    Free Refrigerator User Manuals ' ManualsOnline.com
Dec 14, 2015 | Refrigerators
Display panel on fridge door display flashing from 4 to 7 and beeps 5 times.
the blast chiller fan has prob failed
also check the thermal fuse on the heating elements that are around the chiller elements {used to defrost the chiller section}
and if there is also one on the fan check it
the beeping is prob an error code
you can consult the manual or phone the makers support number
to get more info on the exact error detected
usually there is some reset error like hold in the button etc and power on then let it go
more any more appliances have this
and if you dont know to reset
even if the error is cleared the unit will remain in this error mode
till reset again check the manual
Jun 19, 2014 | Amana SXD524VW Side by Side Refrigerator
What are the recommended aquarium chiller brands available in the market?
I highly recommend you to get a USA Prime Aquarium Chiller you wouldn't be disappointed. You can also get chillers from Aqua Logic Aquarium Chillers, Deltec Eco Cooler Aquarium Chiller, Coolworks - IceProbe Aquarium Chiller, Oceanic Aquarium Chiller, TECO SeaChill Chillers and Tunze Aquarium Chiller the all solid chillers companies.
Aug 13, 2012 | Fish
I have a kitchen selective mod. #BC 10R I dont have the operational manual for this and cant seem to get it to work. I dont know if it is broken or if there is an operator error. Please help me out. We use...
Hello, couple things first. This is posted under a cm-202 coffee maker yet the BC-10r is a wine chiller. Yiou are looking for the instructions for the wine chiller correct? Also I am a service repair person that repairs refrigerators and coolers as well so if you can describe what the unit is doing when you turn the unit on or plug it in as well as if you can see any led lights lit on the unit as well I would be able to tell you what is also wrong with you unit also.Please provide full model numbers and any serial numbers as well on your unit. I await your reply
Thank you
Rick
Nov 24, 2011 | Kitchen Selectives CM-202 Coffee Maker
Our york MAXE screw chiller tripped on CONDENCER-HIGH PRESSURE-STOPPED when i want to reset means it asks password,what is the password
My chiller was high pressure trip and i cannot reset the fault using 9675 and 1380 passcode! What should i do ?
Nov 24, 2010 | York Yankees Bedding MLB Comforter
Chiller wiring diagram
Contact the manufacturer through the tech support line located in your owner's manual.
Jan 29, 2010 | Heating & Cooling
Need manual for waring pro wine chiller model pc150
Go To wamhomecenter.com pull up product, check product details, click on product then print
Feb 22, 2009 | Waring Wine Chiller - Black
Thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Feb 01, 2009 | Waring Wine Chiller - Black
Can i stop the defrost mode on my FR48 glass chiller?
Turn off power to unit for short time this will reset unit.
Aug 04, 2008 | Perlick FR48 Commercial Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
