Question about Air Tools & Compressors
How do i replace belt on a husky h1504st air compressor
5 Suggested Answers
digritz
  • 530 Answers
SOURCE: husky air compressor/1.5 hp
Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
Posted on Jul 29, 2009
ollie reece
  • 1167 Answers
SOURCE: Belt Replacement on Husky Q26 Air Compressor
YOU HAVE TO TAKE COVER OFF LOSEN THE BOLTS ON THE MOTOR SO THE MOTOR SLIDES TO THE RIGHT SO THEN PUT THE BELT ON THEN GET A CAR JACK AND PUT BETWEEN MOTOR AND PUMP DO THE JACK UP TILL BELT GETS TIGHT AND TIGHTEN BOLTS UP ON MOTOR X4 GOOD LUCK
Posted on Aug 25, 2009
  • 5 Answers
SOURCE: I need a new belt for my Husky air compressor but I don't know
You may be able to find the belt you need on ebay. There is a seller named "Footballcardcellar" who lists these often and they are alot cheaper than buying the kit from Husky. Just search "Air compressor belt husky"
Posted on Mar 28, 2010
  • 1383 Answers
SOURCE: How do you replace the regulator valve on a husky
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Posted on Jan 01, 2011
How do you replace a belt on ***** air comprester
Most modles you can either loosen the pump or the motor and slide them together. the belt should roll right off.
Sep 15, 2014 | Husky Air Compressor. 2 Gal. Portable...
Need to find out how to replace belt on WL65 cambell hausfeld air compressor
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
Compressor diagram and parts list:
http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
Pump parts list:
http://www.mastertoolrepair.com/wl390100-p-17694.html
Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Air Compressor has rattlling noise!
buddy im an engineer on these machines for 30 years and when this problem has occured believe it or not but it cheaper to buy another pump unit or compressor plus its the hardest job getting the crank out so your choice bud
Nov 16, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Need the napa belt number for this. or wherever i can get a belt for it.. i dont have the belt that was on it
Measure this with a tape - go to NAPA and tell them what you are doing and give them the distance around the two pullies. The NAPA affiliates I have used in the past have had a very liberal return policy if I was in error.
Oct 21, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have a broken belt
NAPA auto parts has replacement belts for cambel hausfeld compressors.Take the old belt with you,The part number will be like a 5177 or a j6 something.Just remove the cover,and loosen the motor to put the new belt back on,pull the motor to where the belt is firm ,but not to tight.Then you are ready.
Oct 05, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Aug 25, 2009 | Air Tools & Compressors
This is a simple way to replace your belt without the old one for comparison. Use a piece of rope thick enough to fit inside the pulley, (cloths line works well). Simple wind it around the pulleys marking where the two ends meet. Cut and measure it. Take the piece of rope and measurement to a auto parts store and ask them to match it up. An automotive belt will work fine.
If this is a flat belt they should still be able to help you.
Aug 07, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
482 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
