Phillips DVP 1013- controlling without remote
Is it possible to control this product w/o the remote control? Often times there are control buttons on the unit to rewind and FF; however, the Phillips DVP1013 only allows us to play, pause, and stop our movie via the panel/unit buttons. Is anyone aware of alternatives to rewinding and fast-forwarding w/o the remote? Thanks.
  • ReiKay May 24, 2009
    I lost my remote and I can only watch a DVD from start to finish...I can pause for a few minutes...but if I take too long, I have to start at the beginning!!! Frustrating!
    Any news on how to work the player without a remote or to buy another remote for a great price?
SOURCE: phillips dvp1013
To make it multiregion, follow these steps:
Press "Setup" button on remote.
Scroll to "Preferences" using the LEFT/RIGHT arrow key.
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number.
You can select a specific region (1 through 6) or region "0" for all regions.
Posted on May 12, 2008
  • 247 Answers
SOURCE: remote for dvp 3150 won't work
welcome-
are you using the original remote or a universal remote? if a universal remote, then you might have the wrong code in the remote. try another code. or dont you have the code list for the remote?
thanks
tom
Posted on Jan 08, 2009
SOURCE: My remote control cannot work on rewind, fast forward or comerical skip. The DVD screen display SET 1.
Hello, I had the same problem and after spending a few hours reading and trying things, I found a solution. Its very simple. Power on your unit (manually) and then on your remote control push and hold at the same time"enter" and the number "1" while pointing directly to your unit and this should solve the problem. Good luck.
Posted on Jun 18, 2009
  • 199 Answers
SOURCE: I turn the unit on and within 5 seconds it shuts
The unit's embedded software is running the system checks before powering up anything that has failed or could be damaged. The microprocessor could be bad too. Check for shorts on the outputs and inspect for burned components.
Posted on Jun 20, 2009
SOURCE: Please help! When I try and press play, I get a
Try to locate your Hold button/switch. Supposed to be on the side, next to the On/Off switch. Turn the Hold switch off.
Posted on May 01, 2010
How to set up remote control so it will work volume and power on my philips tv the sony player i have is a dvp.sr200p
Why not use the Phillips remote to control the DVD instead of the reverse?
The Sony codes are listed below.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
Jan 01, 2016 | Sony DVP-SR200P DVD Player
What code for ge universal remote 24991 operates phillips dvp 3982/f7?
Note: most remotes allow you to find the code by manually turning the TV (or other device) on first, then press the appropriate button (cable, DVD, surround, etc) then setting the the remote in the "program" mode, then keep pushing the "off/power" button until the TV (or other device) turns off, at that point the code is set.
Aug 15, 2014 | GE 24991 3-device Remote remote Controls /...
To program Phillips DVP 5982
To which device do you want codes? Provide more details please.
Nov 12, 2012 | JVC RM-C14G-1H Remote Control
Sony DVD Player not working
The controller board is slowly dying. I think it might be time to buy a new DVD player.
Aug 19, 2012 | Sony DVP SR510H - DVD player
Sony DVP-S7000 DVD player does not respond to front panel buttons or the remote control
The only possible solution and it is a long shot, unplug unit from wall receptical, now press and hold power for 60 seconds, this will drain any residual voltage and reset the microprocessor in hopes it will work. If this fails I recommend the sony technician.
Jul 17, 2012 | Sony DVP-S7000 DVD Player
Advent code list
Phillips tv: 1002 1003 1004 1008 1012 1019 1062 1068 1069 1075 1076 1087 1219 1238
Samsung tv: 1004 1005 1006 1012 1013 1015 1017 1019 1082 1104 1105 1106 1171 1172
Symphonic tv: 1026 1033 1038 1046 1155 1189
Toshiba tv: 1000 1048 1072 1105 1109 1118 1160 1190 1241
RCA tv: 1000 1003 1005 1006 1019 1054 1096 1098 1099 1100 1101 1102 1103 1129 1179 1188 1190 1203 1240 1252
Citizen tv: 1004 1006 1008 1016 1038 1105 1132 1171 1174 1177 1191
Panosonic TV: 1003 1054 1062 1109 1170 1248
Sep 19, 2008 | Recoton Advent Advent ADR-560 Remote...
Need code for phillips remote
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 09, 2008 | Philips Televison & Video
Televison & Video Logo
572 people viewed this question
Top Televison & Video Experts
