Question about Datel Xbox 360 Turbo Fire 2 Wireless Controller with Rumble
Left toggle sticking/won't work
Left toggle won't work, it sticks and when i enter a game all i do is spin in circles looking upward. just bought it last night, didn't even have it for 24 hours and i'm already having issues with it.
My left analog stick button won't work on my Xbox 360.
Try using the stick on the Xbox Dashboard. If this doesn't work, you need to use a different controller or attempt to repair your controller.
Jan 21, 2013 | Microsoft Xbox 360 Console
ZOOM BUTTON STICKING..how do i fix this?
It is possibly an issue with the zoom motor, not the switch itself
Aug 21, 2017 | Agfa Cameras
IS THERE ANY WAY TO LOOSEN THE POINT STICK SO IT WILL MOVE MORE FREELY
Why does it not have a touchpad? Maybe the touchpad driver is not installed or the touchpad has been disabled or is toggled off.
First off, you can always use a usb mouse instead of the point stick.
Click Start/Control Panel and look for the Mouse and open it to check the mouse properties. Make sure you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and Hold the ALT or FN function key located at the lower left portion of the keyboard, then hit the key that toggles the touchpad. The correct key to hit will have the icon of a finger pointing at a square that represents the touchpad.
Try downloading and installing the touchpad driver.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Touchpad drivers.
May 15, 2012 | IBM ThinkPad T20 2647 Notebook
When playing any shooter game my right analog stick always looks up but the stick isnt upward and i took it apart the resembled it and it worked fine but after a few minutes it went back to looking upward...
This is coud be a result of the metal stick underneath the analog being loose and there is no real solution to this. You can try to take it apart and trying to secure the metal rod that comes out where the analog is by hitting it down more but this usually happens after wear and some good beatings but is not a major problem.
Jul 11, 2011 | Microsoft Xbox 360 Controller
WHERE CAN I DOWNLOAD A COPY OF THE NASCAR 07 INSTUCTION MANUAL?
I couldn't find a downloadable copy but got a hand written one:
NASCAR 07
RACING CONTROLS
Directional Buttons Steering
X Button Share Draft
Triangle Button Reverse
Square Button Intimidator
Circle Button Change View
L2 Button Brake
L1 Button Shift Down
R2 Button Accelerate
R1 Button Shift Up
Start Button Pause
Select Button Toggle Mirror
Left analog stick (L3 Button when pressed down) Steering
Right analog stick (R3 Button when pressed down) Team Communicator
Jul 08, 2011 | Electronic Arts NascarĀ® 07 for PlayStation...
When I try to play a game (Call Of Duty WaW), it won't let me look up, and makes me spin around. I thought it maybe was the Look Inversion in the options, so I changed it, but then it only let me look to...
If you spin around that means the right stick is being pressed in a direction without you even touching it because of loss of calibration. There are some calibration utilities online but for the start you can let Windows calibrate your gamepad.
Open control panel -> classic view (on the left) -> Game Controllers -> Select your controller -> Properties -> Settings tab -> Select Calibration and follow the instructions. If during calibration you see that the right and/or left stick is being pressed in a direction, it is a hardware issue. In such cases replacing the controller is a better option. If it is still under warranty you can get it replaced. If you bought it from Game stop they do normally accept returns within a month or so.
There is one thing you can that sometimes works: Press the right stick towards right and turn it fast in a circle all the way through clockwise. Repeat it 3-4 times and then do it anti clockwise. It works for me each time my controller acts like that, I dont know how but it doesnt matter. Hope it works.
Apr 04, 2010 | Microsoft Xbox 360 Controller
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
Don't know what you are supposed to do on this game
It's a rhythm game kinda like Guitar Hero or Rock Band but not as intuitive or entertaining. My kids have the game because they love the Chipmunks but they haven't touched it in months.
You play by holding the Wii Remote and Nunchuck like drum sticks. You have the wave either your Right or Left hand in time with the circles on the screen. On medium or hard you need to hold a button down on the nunchuck or Wii remote when the circle go upwards. Once you get the hang of it it's really quite simple.
Mar 28, 2009 | Eidos Interactive Video Game Consoles &...
When playing the control keeps turning to the right
So the stick is sticking?
hmmm try moving it about in circles, if this dont wory you could take the control apart and clean the bearing of it this will work fine :)
Feb 16, 2009 | Sony Playstation 3 (PS3) Console
Datel Xbox 360 Turbo Fire 2 Wireless Controller with Rumble Logo
105 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
