Question about Coffee Makers & Espresso Machines
Haden coffeemaker 10608 only some water goes in pot rest stays in filter.
Only some water goes in pot rest stays in filter brand newgift
4 Suggested Answers
SOURCE: My Toastmaster TCM4R coffeemaker stopped working for no reason
do you want mine?
Posted on Apr 21, 2009
co7196
  • 3433 Answers
SOURCE: My coffemaker won't brew
Adequate power and everything in place? Ck for any inconspicuos switches. My coffee pot has two.
Posted on Aug 27, 2009
NewsView
  • 40 Answers
SOURCE: Overflow of carafe
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual and/or do an Internet search for tips.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir, and the lines on the side of the indicator window as your guide. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Therefore, a 12-cup machine may make as few as nine 8 oz mugs of coffee.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve feature, if applicable, isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. It is vitally important to clean your machine with vinegar or as instructed by your user manual at least three times per year and monthly if under heavy use in a hard-water area. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Posted on Jan 04, 2010
The water isn't coming out of my cuisinart coffeemaker model PG-18423! It's on but what do I do?
Age? Warranty? Highly likely the electrical connections and controls internal are bad. Probably time to replace with a lightly used replacement. It may be less than repair.
May 02, 2015 | Cuisinart Coffee Makers & Espresso...
Cuisinart coffe maker does not allow water in
Common problem, it is hard water issue, these coffee makers do not handle even slightly hard water as deposits build up quickly blocking water flow to element. Try one of the many coffee pot cleaners, but if it is as bad as described, may not be enough to clean out coils.
CERACOAT-NANOTECH.com
Apr 21, 2015 | Cuisinart Coffee Makers & Espresso...
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
Water gets stuck in the filter
Inspect the strainer basket's valve to make sure it is not blocked and working properly. You should be able to test it in the sink, fill with water and push the valve up from underneath. Tap the valve a few times to loosen any debris that might be blocking it.
Make sure the pot is fully in place on the warming plate. The lid must align properly with the strainer basket to open the valve adequately. If the pot lid is not touching the strainer basket valve, you may have the wrong pot or the strainer basket is not seated into the coffeemaker correctly. Check for obstructions underneath the strainer basket. Then, make sure the rounded projection aligns with the notch in the coffeemaker near the reservoir.
Jul 10, 2012 | Mr. Coffee JWX27 12-Cup Coffee Maker
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
The coffeemaker is leaking water after pouring to start the next pot. It is clear water that is not hot. Let me know if there is a fix.
There are overflow apertures at the back of the pot, might it be there is slightly more water than the 12 cup capacity? or Does it leak from the top of the basket.. that would indicate that there is some blockage where the coffee exits the filter basket. I have also noticed that if you use a very fine grind the drip process is slowed down and the water backs up. See if that helps, if not ask again stating what you have tried.
Feb 11, 2011 | Waring Pro 12-Cup Coffeemaker
Coffee Makers & Espresso Machines Logo
69 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
