Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Oven door won't close and oven function knob gets too hot to touch
I have a SA 398 X1 about 7 years old and the door won't close completely. There is only a gap of around 5mm and the oven doesn't seal. Do I need to replace the hinges? A second problem is that the upper left side of the oven including function knob becomes very hot. The right side is quite cool to touch. I don't think this is related to the door as the gap is bigger on the right hand side. I'm wary of sinking a lot of money into it as I have already had to replace the rear element at some cost. Any advice appreciated.
    Top Expert:
  • Smeg Master
  • 76,848 Answers
I would not use the oven it is unsafe.
Posted on May 12, 2017
SOURCE: SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Posted on Oct 05, 2008
barkencoa
  • 3463 Answers
SOURCE: SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Posted on Dec 15, 2008
barkencoa
  • 3463 Answers
SOURCE: no heat when i switch oven on
There is no doubt that it is the element that has failed, so all you need to do is replace the fan oven element.
If you can see a removable panel at the rear of the oven ,remove that, and you should see the element.
Remove and replace.
If ther is no removable panel then you will have to access it from the rear of the oven cabinet.
Plz rate my solution.
thanks,
Posted on Jan 02, 2009
SOURCE: Smeg oven door off hinges
go to the last couple of pages on the pdf...I found that the little notch on the bottom part of the hinge fitted on the outside edge of the slot - not as it appeared (to me) on an internal sort of bar. Looked at the smaller of the two ovens and its the same (doh! only made sence when I looked at the diagram!!)
Posted on Aug 14, 2009
SOURCE: SMEG SA708X oven's symbols have rubbed off, wioul
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Posted on Jun 01, 2010
Knobs on hob above the oven getting very hot. Guess heat must be escaping from the oven. Any suggestions?
Try putting a layer of insulating materials between the Knob and the oven. That should help.
Aug 10, 2015 | Ovens
Amica oven door gets so hot that my child has burnt hes hands and needed medical attention
Amica is a European brand, I recommend you contact the company headquarters or a competant local repair shop. Any oven left at a very high temperature for a long period of time gets pretty hot, though, and an eleven month old baby has pretty tender skin.
Jul 19, 2014 | Ovens
1965 Moffat Electric Built-in oven - model #21K90. No manual and no information on any of the websites I've searched. There is power (oven light, warmer light, rotisserie, power rack), but clock and...
My father solved this one, those clocks were such a hassle, ours buzzed for days til he fixed it. It requires opening the control panel and bypassing the wiring that allows the clock to turn the oven on and off. Of course you lose this function. Is that the complete model number?
Oct 26, 2013 | Ovens
I have misplaced the manual for my oven and I need the self cleaning instructions. Model # RF365PXDQ0 Serial # FE2007966
First remove the racks, broiler pan (complete) and any aluminum foil that is in the oven. Hand clean any large deposits inside the oven. Use a non-abrasive cleanser, not an oven cleaner. Clean around the door frame and the edge of the door (outside of the gasket) with hot water and detergent. Close the door to the oven and make sure there are no plastic utensils near the vent of the oven. Make sure that your kitchen is well ventilated.
Next move the lock lever to the right. Set the Oven Selector and Oven Temperature both to Clean. Make sure that the clock, Start and Stop times are set to the correct time. Then push in and turn the Stop time knob clockwise to 3 hours (normal cycle). Make sure the Start time knob is not pushed in. Now wait for the cleaning cycle to be completed and for the oven to cool down. The lock lever can not be moved back to the left until the oven is cool. Forcing it will break it. Turn the Oven Selector and the Oven Temperature knobs to Off.
The manual is available here: http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203189075.pdf . If the direct link doesn't work, start here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=WHRCOM and enter the model number and then click Go.
I hope this helps.
Apr 27, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
My grill on my oven is melting the knobs and the heat is that hot i have to stand away from the cooker i have to switch the knobs off a tea towel and it fills the kitchen with smoke is this covered under...
I assume that you are grilling with the oven door open and not closed, if you are grilling with the door closed, then this will cause an overheating problem,if this is not the case, then I would suggest that the grill regulator is faulty,. and needs replacing.
It not covered by health and safety rules.
Please leave any comments you may have, as I like to know if my comments are appropiate.
Thanks.
Nov 25, 2009 | Belling Ovens
Hot point oven 20 years old cleaned oven now door
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Oven door getting too hot
other than checking the door seal itself, make sure its intact and door closes properly. make sure door' doesnt spring back open after closing does the opening along sid look to be even all the way up the side. maybe the oven door opens more than 90 degrees?? if it does id look into replacing the door hinges
Mar 14, 2008 | Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
83 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
