Question about Epson NX510 Printer
Epson NX510 printer starting a print job then it cancels it itself?
I send the job from my computer, it sends, the printer acts like it is starting to print then the screen on the printer says Cancelling....... and then it goes back to it's regular screen with nothing printed.
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
  • 26 Answers
SOURCE: Skipping lines
you should run a printer head cleanup and verify your cartrages are all full
Posted on Mar 08, 2008
Basti
  • 1447 Answers
SOURCE: Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Posted on Jan 03, 2009
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
aicaxz
  • 511 Answers
SOURCE: Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
Posted on Jun 01, 2009
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Jul 15, 2014 | HP LaserJet P4014n Printer
Afetr sending job to printer and decide not to print it. how do I cancel the job?
Open the Start menu and click on 'Printers and Faxes' or Control Panel>Printers in Windows 7. Right-click on the printer and click 'Open', this will display the print qeue, you can right click on print jobs and cancel them, pause them, or restart them.
Aug 22, 2011 | Epson Office Equipment & Supplies
Hi, as i turn the printer on its start to print some code!! It seems its on the memory of the printer. Even if i unplug the usbcable it prints by itself. I tried do restore the default config but nothing...
If you are running Windows, then your printer buffer is trying to send the print job to the printer.
Look down below in the STATUS area near the time. See if you have a printer ICON. Select it and choos to CANCEL print jobs. Then after all jobs canceled, turn your printer back on.
Aug 02, 2011 | Zebra TLP 2824 Printer
LQ 570 Printing garbled text
1st you cancel all the print jobs from the pc .
In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs.
Jan 12, 2010 | Epson LQ 570+ Matrix Printer
When I print blue horizontal lines appear or being printed as wel
Do the cartridges ride on the printing carriage, or do they plug in somewhere else in the machine and have hoses that run the ink to the print head? If they ride on the printing carriage and the cartridge is new, there could be a short in the printer and it needs repair. Check if there's ink smeared on the print head or part of the printer. Generously clean the print heads with lots of paper towels and rubbing alcohol. If that doesn't work, to see if it's an issue with computer, print a test page from the printer, but don't send the print job from the computer. You need a print job generated from inside the printer itself. Not every printer can do this, but try pressing paper feed, holding down paper feed and power, or holding down cancel and power. If the blue lines disappear then but they didn't when you cleaned the heads, it's a software issue.
Sep 17, 2009 | Epson Stylus Pro 4800 Color Photo Printer...
Printer shows ready, whenI send a print job to the printers it displays printing, but does not print. The unable to cancel or remove printing jobs.
Check if the printhead starts moving when powering on the printer. The problem might lie in the printhead electrical contact pints in which case clean it gently. Alternatively replace the print cartridge where at least black ink is present. If these are OK but it wont pull in the paper then the rollers might be jammed. If its a laser printer,check by changing the tober cartridge amd post the result as a comment.........sodeep
May 11, 2009 | Computers & Internet
Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Apr 21, 2009 | Zebra Z4Mplus Label Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
How to cancel a print job
Press the printer key. The printer screen will appear, and reset job will be an option. You must clear the print queue on the computer or it will just get sent again.
Nov 27, 2007 | Gestetner 10512 Printer
Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Sep 01, 2007 | Brother MFC-7220 All-In-One Laser Printer
Epson NX510 Printer Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
