Question about Tefal UltraGlide Easycord FV4256 Iron
Tefal express iron steam keeps stopping after a while
After about half an hour of ironing, the steam stops. I switch it off and after a while I turn it back on it works. Can you tell me what is the problem?
snakehead
  • 1074 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Posted on Apr 18, 2007
ginko
  • 19396 Answers
SOURCE: Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Posted on Feb 17, 2009
  • 1525 Answers
SOURCE: 2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Posted on Mar 20, 2009
aguywithfeet
  • 20 Answers
SOURCE: Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Posted on Apr 02, 2009
ginko
  • 19396 Answers
SOURCE: tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Posted on Apr 22, 2009
Iron when switched on heats up but does not steam. Model 5 yrs old, Tefal Express
It could just be blocked. To unblick you can pour vinigar in the iron, then switch on as normal. Put iron to cleaning mode if it has the option, or else tilt the iron to let it start steaming. The vinigar should clear the blockage and iron should work normally if the internals are not damaged.
May 10, 2016 | Tefal Irons
My tefal express 2941 steams constantly when switched on and cannot be stopped, please advise?
Fill the iron with 50/50 water and vinegar and let it steam for as long as it will. This will clean out the iron thoroughly, the green light will stop flashing and it will go back to normal. Then remember to clean your iron on a regular basis. Mine did!! Found this solution on another site
Feb 20, 2010 | Tefal Irons
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 | Irons
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Tefal UltraGlide Easycord FV4256 Iron Logo
52 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
