Question about Canon Office Equipment & Supplies
Canon COpier NOP 6030 error code E064
When I switch on displays to "power off and on again". As i did it copying but no print and error code E 064 showing. Can you advise me in this regard ?
  • Anonymous Nov 27, 2008
    When I turn on the copier, it sets itself, then I press Copy and it begins, then only goes approximately 4 inches and then shuts off.
Hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Posted on Mar 14, 2009
No clarity how can get clarity.can i learn canon problem solving course any whre?
Posted on Dec 30, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
E064 Composite power board or DC controller
this is for the 6035, could not find it for the 6030 ( which is the same machine just 5 copies faster)
Posted on Oct 28, 2008
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
064 code
Symptom
E064 is indicated on the control panel. The error description is: The presence of a high voltage error is communicated by the composite power supply. The output for primary charging, developing, or transfer has deviated from a specific level of voltage.
Cause
* Adjustments in Service Mode are Incorrect
* Transport Assembly is Not Engaging Properly
* Dirty HVT Contacts for Developing Assembly and Charging Rollers
* A Paper Clip on HVT Contacts or Developing Assembly
* Faulty Transfer Roller
* Faulty Static Charge Eliminator
* Defective Composite Power Supply
* Defective DC Controller PCB Assembly
Action
1. Check the values in Service Mode and make sure they correspond to the Service
Label. If the copier receives a spike or surge through the 240V line these values can change (can also give you blank copies). Take particular note of the Dev Bias
setting. [COPIER > ADJUST > DEVELOP > DE-DC]
2. Make sure the Transport Assembly is engaging properly. The Transfer Roller should
make good contact with the drum. Check condition of screw (XB6-7501-007) and
Pressure Plates (FB5-4816-000 & FB5-4817-000) for the Transport Assembly.
3. Clean HVT contacts for Primary/ Transfer Charging Rollers and Developing
Assembly. Inspect for any paper clips.
4. Replace the Transfer Roller (FF6-0104-000).
5. Replace the Static Charge Eliminator (FF5-7246-000).
6. Replace Composite Power Supply followed by DC Controller PCB Assembly
Thanks
Dec 17, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
What is the reset for error code E000004-0010?
This is fixing error code. The E004 is heater has failed - this usually last the life of the copier. The 0010 part is that the copier was turned off without resetting the error not a problem to reset. After resetting the error, fire up the copier and write down the error as displayed if it comes back. The sub code is very important to correct the problem. Some codes mean you have to replace the fixing heater power supply or the DC Controller. This is how you reset the code: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Press copier, function ( across the top of display ), CLEAR, ERR, then OK. Turn off copier and power back up. If the error happens again you may have a major problem that a tech may have to resolve. Good Luck.
Nov 02, 2010 | Canon imageRUNNER 5570 Copier
Ir 400 ada kode e064
A Error code E064 deals with the transfer roller unit. I would look to see if the roller feel out of place or I would replace the unit.... Good Luck
Sep 19, 2010 | Canon imageRUNNER 400S Copier
Canon np 6030
Is it looking for toner or is there still a jam in it. You may want to try to turn it off and unplug the sorter and turn it back on. If that dose not work turn off again and unplug the adf and turn it on again. If that dose not work if you have unplug the bottom 2 trays. If one of those is causing the problem look deeper in to one of those units. Also, will it showw or flash a error code on the display?
Mar 18, 2008 | Canon NP 6050 Copier
Canon NP 6025 Main switch is broken, can't find parts.
I've bought a switch for a np 6030 ( even though they said it was not made anymore) canon uses the same parts for several of their machines. You can find the switch on this site where I got mines http://www.precisionroller.com/
you will have to go to the next closest model, I think I bought a 6035 or 6045 switch. worked fine.
Now you MUST realize that the switch turning off is a safety device and acts as a fuse. If it's not staying on it's because there is a problem most likely with your fuser.
Dec 10, 2007 | Canon NP 6551 Black and White Copier
Canon NP 6030 Error code E010
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
540 people viewed this question
old marine
old marine
