Question about Toshiba estudio 255 Copier
F105 reboot call for service - Toshiba estudio 255 Copier
  • Toshiba Master
  • 643 Answers
[F105] HDD other error
Check if the connectors of the HDD are disconnected.
Check if the connector pins are disconnected or the wires of harnesses are broken.
Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
Posted on Jul 14, 2012
My Hoover f105 steam.vac brushes wont spin
Has the belt snapped? I can't find an f105 are you sure you have the correct number?
Jul 15, 2014 | Vacuums
F105 failed error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover t he data in the HDD. If
(4) Replace the SYS board.
U need to update firmware if replace HDD
Sep 16, 2013 | Toshiba E-studio 281c Copier
GE F105 error
According the service guide, an F105 error is "Zero cross failure"
Correction action is:
(1) Recycle power to the cooktop (i.e. turn breaker off and on)
(2) If fault persists, test the line voltage supplied to the cooktop at the wall outlet. Voltage should read from 175VAC to 265VAC. If it does not, there is a problem with the power being supplied to the cooktop.
(3) If fault persists, replace power board
(4)If fault persists, replace main (Logic) board and recalibrate elements.
Mar 31, 2013 | GE 30 in. Profile JP939 Electric Cooktop
Error F105
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
Oct 22, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
Thanks
Best Regards,
Jun 30, 2010 | Toshiba Office Equipment & Supplies
Bonjour j'ai un probleme d'error f105 comment resourdre ceprobleme studio450
Hi how are you this is jack... (jack_pak@hotmail.com).
Dear follow the procedure.. and check these all things..
(3) Perform the bad sector check. If the check result is OK, recover the data in the HDD. If
PLEASE VOTE ME .
Thanks
Best Regards,
Jun 07, 2010 | Toshiba E-Studio 161 Copier
Error code F105 studio 450
F105 indicates HDD other error
Sep 17, 2009 | Toshiba e-Studio 350 Copier
ToshibaStudio 350 , showing code F105
F105 indicates HDD problem.
U need to check followings:
(2) Check if the connector pins are disconnected or the wires of harnesses are broken.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the
Jan 25, 2009 | Toshiba e-Studio 350 Copier
What is error code f105 for an toshiba e-studio 520 copier?
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Dec 20, 2008 | Toshiba E-STUDIO 650 Copier
Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
Dec 30, 2007 | Toshiba e-Studio 350 Copier
Toshiba estudio 255 Copier Logo
469 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
