Question about Bosch SHX43M02UC 24 in. Built-in Dishwasher
What does the heat fuse look like in a bosch dishwasher shx43m02us
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch exxcel dishwasher SGS43EO2 not heating water.r
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Apr 20, 2011 | Bosch 24 in. SGS43E02 Exxcel Built-In...
The machine does not heat up
Bosch dishwashers do not have a heated dry option, the water is heated with a inline water heater but it does not have a heating element to dry the dishes. Make sure that you use jet dry and that you open the door when it is done, after an hour or so the dishes will be dry. This is a common issue with the Bosch dishwasher, but not a problem with the unit
Jan 05, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher will not dry dishes, washing is fine. Model SHU43C05UC / 17. About 4 years old. Cannot find the manual. Any help is appreciated.
Bosch dishwashers do not have built in heated dryers. Be sure your water is hot enough and the rinse aid dispenser is not empty. The Bosch should heat your water to a minimum temp and if it is not, this could be your problem.
Ken
Oct 25, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
I have a Bosch she44c dishwasher that I used just this morning. This afternoon I went to turn it on and a fuse in the panel box tripped. Is there something in the dishwasher that could go bad that...
In some cases, the heat element lining wears out and the element shorts out to the chasis of the dishwahser, thus tripping your fuse.
In other cases, the dishwaser leaks water, and shorts out an electrical component.
It is best to get a repairer to check this out for you.
Regards
Ash
Nov 15, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
It does not heat up or dry the dishes
Depending on the make of your DW, the Heating element inside the bottom of your DW might be at fault.
Your may have a fuse that connects to the heating element that may have blown- relace fuse.
Check the heating element to make sure it is functional.
go to Appliancepartspros.com and enter your model number and find schematics of your DW to see where these things are on your DW
or if you have bosch dischwasher read this:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Nov 01, 2009 | Dishwashers
Bosche dishwasher
check the junction box under the dw on the right front side. sometimes where the power lines come in they fail to tighten the wire nuts and they heat up over time and melt leading to the kind of problem your describing
Nov 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHX43M02UC 24 in. Built-in Dishwasher Logo
16 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
