How can we solv hp pavilion 1x2000 when is not display
How to solve the problem
Iceman999
  • 45 Answers
SOURCE: HP Pavilion N5190
Hello Guilmz,
I will take it that you have (of cause!) tried it with a new fuse in the plug....so forgetting THAT fix, the only things to do are:
1. Remove the battery and plug the laptop in to the mains. IF IT BOOTS then you have a short in the battery compartment electronics. This is beyond most people to fix so take it to a repair center.
2. IF RUNNING FROM BATTERY: Check that the battery fits snug and that it is not loose.
3. IF RUNNING FROM MAINS: Check that the power connector (In to the laptop) is not worn or loose and that the power socket (wall) is on and/or is working.
4. Try it with another adapter. If you dont have one, nip down to your local computer shop and just ask them to plug it in to a known working adapter to eliminate the possibility that your adapter is not working....or take your adapter to them and get them to plug in it to check if it is working...either way you eliminate the adapter as the problem.
5. IF and I say IF you are up to the task...then strip down the laptop and using a magnifying glass look at the mircofuses around the power input socket to see if there are any that have broken or if their are ANY dark or burnt looking ones...or if the motherboard around them looks dark as if it has overheated.
If this is the case you really need to either get it repaired or buy a new motherboard as a power spike may have caused the damage.
I do hope that this helps you, but laptops are hard to fix...even if you know what to look for...and the cost of a repair may be more than it is worth.
Posted on Sep 12, 2008
LaptopExpert
  • 458 Answers
SOURCE: hp pavilion zd8000 inverter problem
you need to remove the front screen bezel (remove the screws and unsnap the cover)
then unplug the Pink and White Power Plug to the LCD Bulb..... Also Unplug the Display cable Plug from the other end of the inverter... Unscrew the inverter from the screen and remove/replace
Posted on Nov 17, 2008
  • 24 Answers
SOURCE: HP Pavilion dv2000 overheating problem
did you make sure that the fan is running? also alot of people run their laptops on the bed. thats a no no. the computer does not get air and it can damage the cpu
Posted on Mar 27, 2009
  • 497 Answers
SOURCE: Hi,
Go to this link and Download/Install any & all Updates for your Operating System.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=385146&lang=en&cc=us&prodTypeId=321957&prodSeriesId=366351&taskId=135
Posted on Jul 05, 2010
sim4182
  • 393 Answers
SOURCE: Dear sir. my laptop hp pavilion dv5, its comming
this is only bios problem .. if u have programmer u can remove bios ic location is near the ram or wireless card no need to open compelete laptop .if u need bios file u can contact me sim4182@yahoo.com
Posted on Sep 15, 2010
I have bought my HP Laptop from India. I have got problem in it. So can I solve it here in Nepal? I can't open it. As I turn on the laptop, virus protection is run. Other thing doesn't display. How does it...
You should probably give us more information first. What "other thing" are you talking about? What *exactly* are the words or pictures that appear on the screen?
Apr 20, 2010 | HP Pavilion dv6000z Notebook
Pinky red tinge horizontal lines near the taskbar in display HP Pavilion dv4
sounds like your power inverter is going bad. replace power inverter and see how that works. Other issue if not solved is probably lcd screen. Inverter's can be found cheaper used if you use the serial number on your old inverter for searching, seeing as how inverters are often used on many different of machines. FYI.
Mar 13, 2010 | HP Pavilion zd8000 Notebook
Go here
No reason to go there. We solve problems here.
Jul 21, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion dv9267ea problem with nvidia Display
I want to share my experienced with 2 units HP notebook; Presario V3000 (V3737tu) and Pavillion dv2000 (dv2505tx).
The notebooks have problem with Intel & NVidia VGA driver , but all the problem now solved by using microsoft display driver (Standard VGA), this way can solving the problem of lowest 4-bit (600x480) and spliting into 8 screen that makes me upset.
This like a virus/worm/malware/trojan or whatever that can makes us very upset ... please also do scan & clean virus/worm/malware/trojan with all free that can be download ... (I am using AVG, Norman Malware cleaner, Virus effect remover, PCMAV) ... Now, 1 of my notebook now can use back NVidia driver again .... the other is still scanning/cleanning, still using Microsoft VGA Standard driver and still working well ...
fferdy@yahoo.com
Apr 03, 2009 | HP Pavilion dv9000t Notebook
While passing video thru from HP 9000DV to tv,,how can I turn off display on pc
The external VGA port is enabled by holding the Fn key down and pressing the F4 key at the same time. There are three modes that can be toggled through:
  • Internal Display only
  • Internal Display and External Display
  • External Display only
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 20, 2009 | HP Pavilion dv9000z Notebook
Hp pavilion zd8000 inverter problem
Nov 17, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
