Question about Xerox WorkCentre M-24 Color Copier
Install Xerox 064K91451
I am looking for guidance for replacing a transfer belt (IBT) in my Xerox Workcentre 24. Has anyone done this before? Thanks!
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 2072 Answers
SOURCE: Xerox WorkCentre M-24 and Windows Vista Home Prem., 64 bit DRIVER
call 1-740-676-8000 ask for Jordan.
Posted on Dec 16, 2008
  • 20 Answers
SOURCE: How to replace the ibt belt or where to buy ibt belt assamble
I have got the new one it cost about $400 usd i you want i show you how to change. Greetings
Posted on May 17, 2009
SOURCE: xerox 242 fault code 042-326
foult code 093-317
Posted on Apr 27, 2010
wrinaldo
  • 185 Answers
SOURCE: how to change ibt belt
The error code 004-346 is an IBT home position sensor. The belt may be damaged or didn't move.
The sensor which is mounted on the frame looks at the belt to see if it made a full rotation. Perhaps the sensor is dirty or damaged. Maybe the home reflective mark is damaged.
The belt may be damaged or shredded. Find out why the old belt was damaged before you install another part!
You probably need to purchase a new IBT belt PN 802K208991. The Xerox technician has a proprietary laptop to clear the codes and calibrate the "Belt Edge." The belt is very fragile, so whoever installs it needs to be very mehtodical and careful.
These may preclude you from repairing that yourself.
Whit Item, Inc.
Posted on Dec 02, 2010
Que signifie le code 089-311 sur workcentre7232
The problem is the ibt belt sensor is not reading the silver patches on the edge of the ibt belt. They are either scratched or the sensor is dirty or faulty. Replace patches and clean or replace ibt belt sensor.
Feb 10, 2015 | Xerox WorkCentre 7232 VSE All-In-One Laser...
Xerox error 089 311
That error signfies a problem reading the IBT belt patch. Check patch and clean and inspect for scratches. It's on the inner side of the transfer belt. If problem still persists after cleaning, replace IBT belt, part number 064K92402.
http://www.iteminconline.com/itemdesc.asp?ic=064K92404&eq=&Tp=
Aug 25, 2014 | Xerox Workcentre 7132 Multifunction Color...
Sharp line on print, even all new drumbs
Is it on prints and copies? Or just prints or just copies.
There are 4 likely causes if the line is on both prints and copies. 1 The transfer belt has a scratch on it. 2, The Transfer belt cleaner, called the IBT cleaner is worn, or the fuser has a cut in one of the rolls. Also the 2nd BTR roll located on the left hand door may be damaged.
If the problem is only with copies, then the scanner glasses or mirrors are dirty.
Mar 26, 2011 | Xerox WorkCentre M-24 Color Copier
I have a Xerox workcentre 7345 and reported that the transfer belt cleaner needed to be replaced. I replaced it and the message is still appearing.
I have a Xerox workcentre 7345 and reported that the Error code 010-341. I Had already replaced Fuser. stil Getting the Same error code
Jan 14, 2011 | Xerox WorkCentre M-24 Color Copier
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Please i need technical help and be able to speak to a live perosn via phone to help with a xerox workcentre 24 color machine. will pay a fee of course. Does anyone have the XEROX software to tell the...
You have to have a fully configured laptop with several levels of Xerox software.
Once that is accessed though you can change those numbers to max them out for the life of the machine.
Where do you live? Maybe I can find someone to do it for you.
Aug 02, 2010 | Xerox WorkCentre M-24 Color Copier
How to replace the cleaning product of belt transfer (m24)? Thank you for your answer
1. Remove IBT Belt Assembly (REP 9.15).
2. Remove IBT Cleaner Assembly (REP 9.16).
3. Remove Stand Plate (Figure 1).
a. Remove screw (2).
b. Remove Stand Plate in direction of arrow. Stand Plate will be installed in new location
in step 7.
Jun 26, 2010 | Xerox WorkCentre M-24 Color Copier
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
Xerox WorkCentre M-24 Color Copier Logo
172 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
