Video output to YUV P-scan and now player wont display on screen!
We recently moved and disconnected all our components from TV. We have setup everything but cannot get DVD player to play any movie in color. I have tried all suggestions posted on different websites. We have 2 DVD players and they both do the same thing. I changed the Video output on the DVD player to YUV P-scan, which made it worse. Now I just get an error message on screen that says "Check connected device's power, cable connection and source connection." I did NOT change any of these other than what's noted above. I cannot get the menu for the DVD player to display on screen so that I can change it back. Help !!
  • 236 Answers
SOURCE: accidently selected s-video connection
you get to the menu options of your TV not the DVD. you should be able to find the input selection for your video.
Posted on May 04, 2008
SOURCE: HELP - Samsung DVD player P347
From the manual...
Connect the DVD to the TV via S-video or Video outputs (not component video) and...
• Press power on from a cold start with no disc in the unit. Press the
SEARCH/SKIP ( ) button on the front panel for 1 second.
The SELECT MENU LANGUAGE display will appear.
Select the number button of the desired language.
regards, Glenn
keraurus (at) gmail.com
Posted on May 24, 2008
  • 24 Answers
SOURCE: How to Connect my Cyberhome CH-DVD 300 from my TV that has SCART interface to Component Out on the DVD player
You have not mentioned the t.v/ dvd model, normaly all latest t.v will have A.V. input , try to connect in a.v. out of d.v.d to a.v. input to t.v and bring t.v. into a.v. mode.
Posted on Jul 02, 2008
  • 7 Answers
SOURCE: How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Posted on Jun 06, 2009
1chinatown
  • 67 Answers
SOURCE: The disc is stuck in the player and the tv screen says it cannot get a signal.
Barbara, your dvd player needs to be either on channel 3 or 4. If you have a local channel 3 or 4 switch it to the one that is not local. Or it could be a video 1,2 or 3. Just keep using the remote in that format and you will find the signal.
Posted on Dec 05, 2011
Video does not work All this while, I had never used the video components of my AVR 1705. Recently, i wanted to connect the component out of the cable set top box and dvd player to the avr and the output...
Hi
The settings on many DVD players and TVs may need to be set to indicate the type of input/output being used(RGB vs YUV/YPbPr, and if set wrong the image may not be properly displayed. Try Look for such settings in your TV and/or Amp!
Good luck
Bruce
Dec 07, 2009 | Denon AVR-1705 Receiver
I have a dvp 3960/37 player I am trying to hookup to a Sony KV 32fs120 TV using YPrPb as a component. The Sony manual says the DVP must be Setup before connecting. The Phillips manual says to use the TV's...
If you are using the component output from the dvd player (3 wire video) progressive scan connect corresponding cable to tv . Besure to match colors. If you are getting a black and white double image you need to set the output of the dvd player to progressive scan. See owners manual for dvd player to set this. The yelow color jack on the tv is composite video and is not compatible with the 3 wire video .
Nov 20, 2009 | Car Audio & Video
DVD ONLY PLAYS IN BLACK AND WHITE
figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
Oct 14, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
No video output caused by OSD change
Leave cables conected to tv as they are but connect L73 to TV with a scart lead, then switch TV av to the one used by the scart lead and hey presto you'll be able to change back to the progressive setting ( component cables ).
Once this is done just remve the scart leads and bobs ur uncle your back in business.
Hope this helps. Earl
Apr 05, 2009 | NAD L73 DVD Player
Connecting DVD to TV
P-scan is used for traditional television screens.
YUV encodes a color image or video taking human perception into account.
S video should be used with an S video cable and standard rca's for sound
Jan 20, 2009 | Televison & Video
Mintek 2110 no component video
You need to change the Video out in the menu.
Press set up on the remote
move down to video out and select YUV output
it should now work
Aug 08, 2008 | Mintek DVD-2580 DVD Player
Split Screen
Go into SETUP
GENERAL SETUP PAGE
Go to VIDEO OUTPUT (can't see through error message, but it is the second one down - If you are on the right one, you will see S-Video, YUV Interlace and YUV Progress. as choices)
Change setting from YUV Progress to YUV Interlace
Mine was set on YUV Progress. and when I changed it, the problem disappeared.
Mar 06, 2008 | RCA DRC200N
Dvd player problem
DEAR
CHECK YOUR AUDIO VIDEO COARD BY REPLACING IT
CHECH AV CONNECTOR OF YOUR TV WAS LOOSE
CHECK MPEG BOARD OF YOUR DVD PLAYER WAS DEFCTED
THANK YOU
Jan 24, 2008 | Sony DVP-NC875V Multi-disc DVD Player
No color when switching to component cable
To Change DVD Player Video Output to Progressive Scan: With your DVD Player turned on, and your TV turned on, press and hold the PREV/VIDEO button for at least 3 seconds (this puts you into Video Output mode). Press the PREV/VIDEO button to access different video output options. Each time you press
PREV/VIDEO, the type of video being displayed appears next to the Display menu. Look for PSCAN on your DVD player display panel. At this time, your progressive scan on TV should be working.
Oct 18, 2007 | RCA DRC233N DVD Player
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
