Question about KitchenAid Dishwashers
How to access control board of kitchenaid KUDP01FL dishwasher
onthejob5130
  • 640 Answers
SOURCE: no power to dishwasher - no lights, etc.
check ,,fuse on control board..onthejob
Posted on Feb 18, 2009
wheelshot
  • 102 Answers
SOURCE: KitchenAid Dishwasher (KUDP01FL) - electrical problem
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Posted on Apr 11, 2009
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
goldenglove1
  • 144 Answers
SOURCE: I have a KitchenAid Whisper Quiet Dishwasher. Has
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
Posted on Aug 07, 2010
  • 3 Answers
SOURCE: Kitchenaid dishwasher KUDS01....
the pump is stuck. remove motor.insert plastic pen into bottom of motor.remove impeller by turning counter clockwise.file bottom of impeller stem.put enough washers on the keeper clip to prevent the impeller and the pump housing from binding.reassemble and there you have it!!!!
Posted on Sep 21, 2010
How to remove the upper rack on kitchenaid dishwasher
The upper rack has a captive washer with a lug that stops the top drawer from falling out. Use a torch, identify the captive washer that is connected to the rear wheel on each side if the drawer, remove these and the draw will come out
Jul 15, 2014 | KitchenAid 24 in. KUDP01FL Built-in...
Stopped midcycle, water not drained, no lights, no reset, input power good
The most probable thing wrong that made your dishwasher just quit mid cycle and wont now do anything is going to be a blown fuse on the control board. It's a fairly common problem with that brand,so much so i have written a tip about how to check it. Here is the link to that tip,
http://www1.fixya.com/support/r10341846-will
GENE
Oct 06, 2011 | KitchenAid 24 in. KUDP01FL Built-in...
My dishwasher needs to be reset. What is the button sequence for this?
see procedure for clearing flashing clean light. it appears to reset everything.
May 17, 2011 | KitchenAid 24 in. KUDP01FL Built-in...
I have a KitchenAid model KUDP01FLBT6 dishwasher. When hitting the "Normal" button and the "Start" button, the dishwasher would run for less than 5 minutes and then shut off. Dishes...
what makes you think it was in a demo mode ?? was it a floor demo model ? as if it was there might be a few things you needed to reconnect before you use it in your home , one that comes to mind is the float level switch , this is usually in front right corner and demo models usually have a foam spacer under there edge , also its possible a demo model could have a special control board in them , requiring you to replace it with a standard model b4 it would work properly
May 27, 2017 | KitchenAid 24 in. KUDP01FL Built-in...
How do you repair or replace the door tension spring on a KUDP01FLBT2 built-in Kitchenaid dishwasher? Thanks
If your door falls down or is noisy I have put together some instructions here on how to repair. You will need a kit part number 8194001, it is relatively inexpensive, let me know if you have questions.
Door falling down or creaking
May 01, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
My built in dishwasher nardi door hook has broken
Contact Nardi Spares in Huddersfield Tel 0845 050 8558. They should be able to supply a replacement catch.
Nov 11, 2009 | KitchenAid 24 in. KUDP01FL Built-in...
Apr 11, 2009 | KitchenAid KUDR01TJ Dishwasher
No power to dishwasher - no lights, etc.
Feb 18, 2009 | Dishwashers
Dishwashers Logo
47 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
