Question about Dell 3100cn Laser Printer
093-943 reseat black cartridge - Dell 3100cn Laser Printer
Dell v305 printer allignment problem
Hello Michelle,
You are using Dell Series 9 ink cartridges, correct?
If you unplug the printer from the wall and remove the power brick for 60 seconds, this will reset any error messages the printer has. I would then plug everything back in.
Power on the printer.
Open the printer(with the power on) and take out the Dell Series 9 black cartridge and then reseat it. I would then take out the color Dell Series 9 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
black cartridge = black side(left side) color cartridge = color side(right side)
photo cartridge = black side(left side) color cartridge = color side(right side)
It's possible to get a Dell Series 9 ink cartridge with a bad sensor. I would take these back to the place of purchase for a replacement.
Bhautesh,
Jan 30, 2014 | Dell Computers & Internet
When I print from the internet my copy prints my color comes out a different color I think it might be my black ink is off I have a dell 946 all-in-one printer.
Are you using Dell Series 5 ink cartridges?
Can you copy a document under the glass? Black & White and color? Do they look ok?
Open the printer(with the power on) and take out the Dell Series 5 black cartridge and then reseat it. I would then take out the color Dell Series 5 ink cartridge and reseat it. Now close the printer and it will print an alignment page.
Any error messages?
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges .
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It's possible to get a Dell Series 5 ink cartridge with a bad sensor. I would that these back to the place of purchase for a replacement or a refund.
Rick
Jul 27, 2011 | Dell 946 All-In-One InkJet Printer
We keep getting left cartridge incorrect message?
Any error messages?
Rick
Jun 12, 2011 | Dell 946 All-In-One InkJet Printer
Refilled ink catridges and printer still shows that the ink is low
Any error messages?
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Rick
Mar 04, 2011 | Dell Photo 964 All-In-One InkJet Printer
My printer keeps flashing check print cartridge, Both black and color are flashing. I have Just bought a new 92 Black cartridge and the color cartridge is full ... why is this happening?
While reseating a cartridge is not difficult but there are a number of errors that can occur if the user does not manage it properly. Reseating a cartridge should not be a difficult task for anyone with a passing knowledge of printers. The reseating error can occur after the user has replaced the black ink cartridge. It is a common problem with the black ink cartridge. The user may attempt to replace the cartridge number of times, clean the contacts and restart the plotter. If there is a problem with replacing the black ink cartridge that cleaning the contact does not fix, then it is best to simply replace the carriage assembly first. If this does not solve the problem then the user may want to consider replacing the trailing cable.
Nov 17, 2010 | HP Office Equipment & Supplies
Model c309g. I replaced the black ink cartridges because of low ink. I am trying to scan black text and it comes out blank. Scan color and it comes out but obviously without the black. I have re-run...
Do you still have the old cartridges, if so did the blacks still put out some ink even just a dot or two. If so put the black cartridge back in and try a sample print. If you just get a mark or two on the paper it may mean that you are new cartridge is faulty.
Sep 11, 2010 | HP Office Equipment & Supplies
Black doesnt work
Its may your black cartridge's ink have been drain so change your black cartridge.
Regards
Ashly
Feb 03, 2010 | HP PSC 1210 All-In-One InkJet Printer
My printer says E 5
Try reseating the ink cartridges. The error references to either reseating or refilling the ink cartridges.
Since you have mentioned that it worked before with only black cartridge, try reseating both and check.
Apr 02, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Cartridge error
try reseating the cartridge & also reseat the power brick assembly.....also if u hv the factory installed cartridges....try installing those & chk if u still get the error...
Jul 05, 2008 | Dell 942 All-In-One InkJet Printer
Dell 3100cn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
