Question about LG Shine KE970 Cellular Phone
Help how do you reset your sim card
You cant
you need to buy a new one if needed
Posted on Oct 29, 2008
Phone was working fine and then all of a sudden the sim card slot stopped reading my sim card.
Samsung Galaxy Mega 6.3: SIM card not working:
Hello. sometimes the SIM card slot gets loose over time.
If you notice that it is easy for the SIM card to slip in and out of the card holder.. or if not you can try this fix anyway to see if it helps:
You'll need some scissors and some clear tape like scotch tape..
cut off a very small piece of tape just enough to cover the top part of your SIM card..
it doesn't have to cover the whole top part..
It can not cover any connectors..
after affixing, slide the SIM card back into it's holder to see if that works..
If that doesn't help, you may have to visit your local Service Provider's store to get a new SIM card
http://forums.androidcentral.com/verizon-droid-dna/276699-sim-card-improvement-maybe-not.html
Feb 11, 2016 | Samsung Galaxy Mega 6.3 Mobile Phone
SIM LOCK CODE FOR SAMSUNG GT-E1087T.
The phone is not any network but still there is a sim lock with unknown password and no other sim card can not be used hard reseting codes default password are not working plz help
Nov 19, 2012 | Cell Phones
My nokia says no sim card and stuck again again
rijamunir, make sure if sim connector is not damaged, and try hard reset 3+*+green button+poer on button press and hold until show insert sim card. then insert sim card , the problem will be solved with hard reset described aboove.
Jun 25, 2012 | Nokia C101 Cell Phone
I took my sim card out last night. and since last night it has said insert sim card at the top of my screen can u help me?
Put the sim card back in if you haven't. Then push the reset button around or near the battery. You might need a paper clip to reset it.
Dec 03, 2010 | Cell Phones
Ii got a unlocked iphone had signal for the first hur or too now has none even tho it says orange has no bars and cant txt or call or recive
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve signal strength issues.
Reset network settings:
In some cases resetting the network settings has also helped so tap Settings, tap General, tap Reset, tap Reset Network Settings.
This will restart your iPhone and will also delete any stored Wi-Fi passwords as well as DNS settings and more.
Place your SIM card again:
If your iPhone’s SIM card is not placed properly, it has been observed that it can affect signal strength.
So a good idea would be to remove your iPhone's SIM card by pushing a straightened paper clip into the small hole on the top of the device to open the SIM tray, then check for debris inside the tray or SIM card slot, remove it by blowing into the slot or using compressed air and then placing the SIM card properly and then re-inserting the SIM tray.
The notion is that improper SIM contact can result in a weak signal, so the above procedure could help.
Attaching scotch tape to the SIM card:
This is indeed the most ingenious methods, it appears that attaching a small piece of scotch tape to the outer side of the iPhone’s SIM card (the side of the SIM card that does not have metal contacts) can result in a surprising boost again borrowing from the notion that improper SIM contact can result in a weak signal.
Jun 02, 2010 | Apple iPhone 3G Black Smartphone
Can not make phonecalls or recieve
Reset the iPhone:
It has been observed that simply resetting the iPhone can resolve network issues.
If your iPhone’s SIM card is not placed properly, it has been observed that it can cause network issues.
The notion is that improper SIM contact can result absence of signal, so the above procedure could help.
May 28, 2010 | Apple iPhone 3G
Poor recepshion on my iphone
Reset the iPhone:
May 25, 2010 | Apple iPhone 3G
What is a sim card reset code
A sim card is also referred to as a puk code which enables you to reset your sim card and all related pin codes in case you forget,
The puk is a network associated code and can be gotten from the sim card packet or directly from the network provider.
Cheers
May 02, 2010 | Samsung A177 Cell Phone
I swapped the sim card for another att card momentarily and then put my sim card back in the phone. The phones number is now that of the other sim card. How do i reset the card/get my old number back?
Have you tried doing a hard reset with your sim card in the phone. With the phone on, pull the battery out and put it back in, then turn the phone on it it doesn't start automatically. It should pick up your info from the card. Let me know if this helps.
Mar 28, 2010 | LG CE110 Cellular Phone
Alcatel OT600, VM621i,sim card locked. Need reset key.
can anyone help me to by posting me a reset key key for alcatel ot-s621 mobile
Mar 23, 2010 | Alcatel Cell Phones
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
