Question about Zebra GK420D Direct Thermal Label Printer
My zebra gk420d printer stops printing.
Help me plz my zebra gk420d printer stops printing, I've deleted it and reseted it when I print test page it print it fine, when I try a second test page doesn't print. once i switch printer off when i switch it on again it will print it. so each and everytime I need to print i must switch printer off and on again, it print one page then i have to switch it off and on to print 2nd page. help plz.
You can ask a printer Maintenance Technician to solve the problem for you.
Posted on Mar 02, 2012
4 Suggested Answers
Madbigwhoper
  • 13 Answers
SOURCE: I am trying to clear
Hopefully you can read this. I downloaded entire manual from Zebra. This section is the feed button options to reset communications, calibrate, print configuration & also to do a factory reset. You will need to try the FACTORY reset. Basically while the printer is on you press & hold the feed button till it blinks 4 times in a row then release. It will blink 1 time then pause then it will blink 1-11 & pause then 1-11-111 then pause then finally 1-11-111-1111 then release. Each 1 represents a blink. I would attach the doc but system is too busy to allow right now.
Posted on Feb 06, 2009
  • 62 Answers
SOURCE: how do I clear the memory on a zebra gk420d?
Download the Seagull scientific GK420 ZPL driver. Version 7.16.
Open the driver file, (Double click on printer icon in printer & faxes folder)
Click Printer, properties, tools, action, reset printer.
Play around with the Seagull driver, it is very useful, you can format memory, read files stored in printer memory, see forms, fonts, images etc.
The forms stored in the G series printers are not cleared by the normal methods which one would use on it's predecessor the 2844 models. The G series will maintain the forms stored in its memory even if you download new firmware, or reset it. This is actually a good thing, as it prevents you from accidentally erasing forms stored in the printer.
Posted on Apr 18, 2009
  • 52 Answers
SOURCE: We have a Zebra GK420d
You can enter the internal web page and set the printer from there. Or from the printer driver, you can set the darkness and speed there.
Or in your label printer software.
Posted on Jan 11, 2011
Not printing properly
Printhead should be cleaned with a 90% alcohol solution, however that should not cause blurry print. I've seen some labeling programs that will blur part of your label after the trial period has expired. I would check to see if this happens on test prints also. Do a test print by holding down the button on power up and letting it go after the first blink.
Jun 09, 2015 | Zebra GK420D Direct Thermal Label Printer
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
Rw420 skip printing
Kindly post the output to the command "debug client <printer MAC address>".
Can you also post the output to the command "sh interface detailed zebra".Or in case You Still Having Brother Printer Problem Then Follow Us For On: Printer Support Team
May 14, 2013 | Zebra PRINTER - RW420 - 4 Inch DIRECT...
Zebra GK420d Driver for my Mac
There is a commercial driver for Zebra printers on Mac OSX, works perfectly with the GK420d printer even from courier Websites and Ebay shipping. You do have to pay for it but it works.
Details are here:
Mac Thermal Driver For OSX Print Directly To Label Printers On OSX
Hope this helps people find what they need.
Jun 11, 2012 | Zebra LP 2844 Thermal Printer
How to printer test page from the display panel zebra zm600
With most Zebra printers, a test page is printed by pressing and holding the PAUSE key while turning on the power. Keep pressing the PAUSE key until the printer completes the POST (power on self-test), then you can let go. A test pattern will begin printing. You can stop the pattern by pressing PAUSE. Turning the printer off & on again is the fastest way to end the test. This is a good page to print because it prints a large black box and it's easy to see if there are any printhead elements not functioning. It's best to use the largest, widest label you have for this test.
Hope that helps !
Aug 29, 2011 | Zebra ZM600 Printer
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
My Zebra LP-2844-Z won't print, says spooling, printing, deleting
try this--open the control panel then open system & maint then admin tools. open services then find the print spooler svc and right click then restart. close all jobs and print windows first then try again
May 15, 2009 | Zebra LP 2844-Z Thermal Label Printer
How do I clear the memory on a zebra gk420d?
Feb 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I am trying to clear the memory on the zebra printer gk420d ... what is the best way to do this?
Zebra GK420D Direct Thermal Label Printer Logo
1,449 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
