Question about Cisco ASA Computers & Internet
ASA VPN setup
How to setup a site-to-site IPSEC VPN between a 5505 and a 5510. Split tunneling required so internet traffic goes through local ISP.
  • 205 Answers
This has been nicely explained here:
http://www.computerfreetips.com/Cisco_router_tips/ASA-VPN-tunnel.html
Posted on Mar 12, 2012
I have comcast cisco cable that is working fine but when I hook up vonage I get no internet why?
More than likely you need to enable split tunneling on vpn settings in router. If Vonage uses a vpn tunnel like other VOIP services do, then it is probably encrypting all traffic on your Internet/WAN interface. With split tunneling enabled it will only encrypt traffic to and from Vonage. I'm making a few assumptions here, but it should be worth a check.
Jul 23, 2014 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I need help with cisco asa 5505 ssl vpn.. ssl
The total sum of the Inside/Outside/ and pool address add up to 5,265. Subtract 10% and multiply by 260 to get the gender aspect of the original formula. Move the Network address to Google and download the residual code offered by the program that appears in the open window. Enter the code in the appropriate space provided and this will solve the problem by late 2015.
Oct 09, 2013 | Cisco ASA 5505 Firewall
Can't access network folder after connect thru vpn
if you connect through vpn and your network folder is in your local network, you cannot access the network folder because you are virtually connected to an external network other than your local network. because of this you are actually trying to find your local network folder that is not present on that external network. you may need to disconnect your vpn before you access the network folder in your local network
Nov 06, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Vpn site to site
you need to create an IPSec tunnel between the router and windows server 2003 (run secpol.msc). From the dlink router, you need to set the IP address of the VoIP gateway as part of the LAN that is included on the VPN tunnel. Since it is the server 2003 that has a static IP, you need to initiate the connection from the Dlink router.
Jun 23, 2009 | D-Link Express EtherNetwork DI-LB604...
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Wanna open gates from the router SIEMENS 5890
u can use the port forward for forwading ur port if it is blocked.
Jan 07, 2009 | Computers & Internet
VPN
the following is from a nice guide i found on the net, see if it works for you: First thing to check is whether your router has any settings for PPTP or IPsec "pass through". These are commonly found in Linksys routers but you may have to hunt around for them on other makes. All you need to do is enable the setting for the VPN protocol that you're using, reboot your router and, if you're lucky, the VPN connection will come right up. Note: Not all routers have these enables and the lack of them doesn't necessarily mean that you can't get VPN working. Open up that Firewall Still no connection? The next step is to try opening some ports in your router's firewall to get your VPN connection made. In each case, you'll need to open the specific ports (and protocol) to the IP address of the computer that you're running the VPN client on. NOTE that port mappings work with only one computer at a time. If you have multiple VPN clients that you need to connect, your router will have to support the VPN protocol that you're using without requiring ports opened. If you're using Microsoft's PPTP protocol, TCP port 1723 is the port you'll need to forward to allow PPTP control traffic to pass. Figure 2 shows the Forwarding screen on a Linksys BEFSR41 set to forward this port to a client with IP address 192.168.5.100. PPTP also needs IP protocol 47 (Generic Routing Encapsulation) for the VPN data traffic itself, but note that this is a required protocol, not a port. The ability to handle this protocol must be built into the router's NAT "engine"?which is true of most present-generation routers. IPsec-based VPN's need UDP port 500 opened for ISAKMP key negotiations, IP protocol 51 for Authentication Header traffic (not always used), and IP protocol 50 for the "encapsulated data itself. Again, the only "forwardable" item here is UDP port 500, which is also shown programmed in Figure 2 to the same LAN client machine?protocols 50 and 51 must be built into your router. Tip: Not all routers are created equal! Some allow only one VPN tunnel to be opened and used by a single client. Others support multiple tunnels, but with one client per tunnel. Unfortunately, most vendors don't make the VPN pass through capabilities of their products clear in their documentation, nor do they have support staff properly trained to provide this information either. In most cases, your only option is to try a router in your specific application, and make sure you can return it and get your money back if you can't get it working. Still not Working? Getting many IPsec-based VPN setups working can be a black art due to the wide variation in techniques used by various vendors. Although IPsec products have become more uniform as the technology matures, your company may use older, more proprietary products that may not be configured with NAT in mind, or require additional ports to be opened in your firewall.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
VPN
This example will demonstrate how to create a Virtual private Network (VPN) between two remote locations through the Internet. The VPN policy will use 3DES IPSec to securely send/receive encrypted data over the Internet. When the VPN tunnel is enabled, the two offices will virtually appear to be on the same local network. This example will consist of two DI-804V VPN Routers with a simple setup. The two remote offices in this example will be known as Office A and Office B. Both VPN Routers must already be set up and able to access each other. This is only an example, your setup will vary using the WAN IP address provided by your ISP. Please note the differences in the IP addresses for each office. We will begin by configuring the DI-804V at Office A. Start by going into VPN Settings under the Basic Setup menu. Step 1. In the Connection Name field, type in OfficeA. Click ADD. Step 2. A properties screen will appear for the new connection you have made. Fill in the appropriate information for Office A: Connection Name: OfficeA Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.1.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.2 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 3 Click SAVE. There should now be a VPN policy created for Office A. Now you will want to Save & Restart the DI-804V. Note: 123456 is an example of a preshared key, please fill in any secret preshared key you desire. Keep in mind that both sites require the same preshared key. Office A setup is now complete, we will now configure Office B with the other DI-804V, Follow the same steps previously with Ofice A to create a VPN policy. Step 1 Please change the appropriate information. Connection Name: OfficeB Local IPSEC Identifier: Local Remote IPSEC Identifier: Remote Remote IP Network: 192.168.0.0 Remote IP Netmask: 255.255.255.0 Remote Gateway IP: 192.170.0.1 Network Interface: WAN ETHERNET Secure Association: IKE Perfect Forward Secure: Enabled PreShared Key: 123456 Key Life: 28800 IKE Life Time: 3600 Step 2 Click SAVE. There should now be a VPN policy created for Office B. Now you will want to Save & Restart the DI-804V. After the VPN policies have been created for the two Offices, the two remote locations should authenticate and connect. To view the status of the VPN connection, go to the Device Status menu. On the bottom-left side of the menu, click on the VPN Status icon. A VPN Status pop-up screen will appear showing VPN connection status. If a VPN tunnel is active, the State should indicate Q-Estab. Go to a DOS prompt and ping the internal IP address of the remote network.
Feb 16, 2006 | D-Link DI 804V (DI-804V) Router
Computers & Internet Logo
410 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
