System Doesnt start automatically
My system doesnt start at automatically. The problem is that when i turn my UPS on the system starts automatically. But it doesnt take the boot device automatically. I have to press F2 and go to bootable screen and exit from that. Afterwards it starts... I tried by changing the device priority but it doesnt work..
  • Rajesh1591 Oct 28, 2008
    Yes... I tried that also... Is there could be cmos battery Problem
  • Rajesh1591 Oct 29, 2008
    thanks... ya.. I will try for that
    Sergeant:
    Champion:
  • 331 Answers
Did u try restoring Ur BIOS to default settings............
that might help
if it doesnt pls do post back a reply
Posted on Oct 28, 2008
  • Varun Kumar
    Varun Kumar Oct 28, 2008
    u may be right the
    battery may have become weak but that ocurs only if ur comp is quite old .......
    so u could try and replace the battery..
    because maybe the data is getting lost during the time the computer is turned off
    but if ur computer is new the battery may not be the problem
APC SILICON 40KW Ups.. on statrting ups it doesnt goes further to any screen display,Red ALaram LED is on(no blinking etc),. can any one guide?
apc silicon 40kw ups,1.check if input phases are complete.2.do a phase swap like changing the phase sequence and see if it will complain sequence error.3.after start-up u need to do a dc start-up,the dc bus is +360/-360vdc and after the dc bud is completed you need to press the green botten to power the inverter.if it doesnt do the dc start-up then go to the log and see what it complains about.write out the complain on the log and forward it to me.08082245266.engnr festus.
Oct 02, 2015 | APC Computers & Internet
Sir, My PC is starting problem, 1.Starting UPS - ON the system starts automatically without swith ON. 2.After Starting the keyboard & Mouse get stuck 3.after Restart the the keyboard & Mouse...
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
Apr 08, 2011 | Intel DG965RY Motherboard
The UPS doesnt charge after a long time is powered to a.c source
there so many causes of batteries not charging, i would advice you to check whether the batteries are okay.
Jan 12, 2010 | APC Smart-UPS 1000VA UPS System
2005 mazda rx-8 automatic will not start
Does it actually crank? If so and doesnt start then its probably flooded. Been a problem with those cars since they came out but not to feel bad theres quite a few cars that flood easy do to certain sensors. If not turning over but just clicks then battery issue just keep in mind every time try to start and it doesnt that more fuel enters the system and doesnt burn off which means more flooding (to much fuel)
Sep 13, 2009 | 2005 Mazda RX-8
Motion sensor(it doesnt want to flip) (doesnt flip automatically)
From the start menu, click on settings. At the bottom, click in the System tab. From there click on motion sensor. Make sure that it is set to Auto. Or play around with the options
Aug 08, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
I hear some tick sounds in ups and the ups doesnt supports when there is a shutdown in power
hello
If the UPS does not support the system when there is a shut down in power it means your batteries are degraded.
you have to replace the battery of the UPS and it will be working fine then.
Thank you
Aug 06, 2009 | APC Smart-UPS 1000VA UPS System
My UPS it just beeping ,when i connect it with a computer it doesnt switch on .
Pres the reset switch and it could possibly be that the battery is incorrectly connected or dead.
Jun 04, 2009 | APC Back-UPS CS 500VA UPS System
Can anyone help me? my maxtron ups doesnt withhold power when the mains is off
have U change with new batterys it might be battery problem. i still doest work with new battery that mean is the hardware issure ask your vendor to come down and check...
May 18, 2009 | APC Back-UPS CS 500VA UPS System
Doesnt power on
On some UPS you have to hold the power button down for 5-10 seconds before it switches on.
May 29, 2008 | Monster Cable MP-HT-UPS-1000 (ht ups 1000)...
Belkin F6C800UNVPL UPS does not auto start
u have problem with ur automatic utility....
contact ur dealer or go to any ups shop.....
they will fix it in a very cheap cost man....dont forget to tell me u r problem solved or not
best regards & best of luck
Oct 03, 2007 | Belkin (F6C800-UNV-PL) UPS System
Computers & Internet Logo
David Payne
David Payne
