Question about Fuji FinePix S5500 Digital Camera
Fujifilm finepix s5500 WONT TURN ON
Hello i have had a fujifilm finepix s5500for about 3 years now but about two years ago it turned itself off and we have never been able to get it to turn back on again we have tried replacing the batteries but it did not seem to do anything is there any buttons or anything that i could of pressed to make this happen
dbarchitect
  • 150 Answers
SOURCE: wont turn on
Only use Ni-MH or AA-size alkaline batteries. Do not use Ni-Cd (nickel-cadmium) because the heat emitted can damage the camera.
I would suggest using e2 batteries from Energizer.
In the manual, on page 80 there is a description and procedure for discharging Ni-MH batteries (but NOT regular batteries, so don't do this with regular alkaline batteries) AND do not do this when the external power is connected.
Moving on... The discharging of the batteries procedure should happen when:
  • the batteries last for a short time after being charged normally
  • the batteries have not been used for a long period
  • the batteries are new.
Follow these instructions:
  1. Press the menu/OK button to display the menu on the LCD monitor
  2. Press the "left" or "right" on the pad to select "SET" OPTION and then press "up" or "down" to select "SET-UP".
  3. Press the "MENU/OK" button to dipslay the "SET-UP" screen.
  4. Press "right" or "left" to move to option 5 and then press "up" or "down" to select "DISCHARGE".
  5. Press "right"
  6. Press "left" or "right" to select "OK".
  7. Press the "MENU/OK" button.
The screen changes and discharging begins. When the battery level indicator blinks red and discharging ends, the camera turns off.
Remember to not have the camera external battery plugged in so the battery can discharge on it's own.
Then, at this point, recharge the battery using the external battery charger. This helps to "renew" the battery. This is because Ni-MH batteries will remember the last place where they recharged, and too many times, the memory "bookmark" gets marked to low and has to be reset, done by the recharge.
It may be necessary to repeat these steps multiple times. This effect is not because the batteries are deffective. This is a normal side-effect of Ni-MH. This is the reason the camera comes with a discharge feature.
I the batteries are old and don't function even after performing the discharge procedure as part of the normal operation of the camera (like of the year or two), then the batteries may have reached the end of their service life.
Hope this helps, if so, please rate FixYa! ThankYa!
Posted on Dec 04, 2007
SOURCE: fUJIFILM FinePix A360
i have a fuji a360 and have lost my cd can you help me
Posted on Apr 23, 2008
my A360 digital wont turn on it flashes green then goes off i put new batteries in it
Posted on Sep 30, 2008
  • 4 Answers
SOURCE: Fuji finepix lenses
See my other post ref long/wide angle lenses.
Just check out ebay - look for fuji convertor lenses, a pair of basic Raynox long and wide angle lenses are about £100 although you can buy higher spec ones for significantly more. With Jessops going through hard times they tend to put these in their junk/clearance bins - I got my wide angle for £1.39 after waiting for about 3 weeks for it to drop in price. Check out when they are closing or clearing stock. Guess all high st retailers will be in the same boat wherever you are based at the moment so willing to sell-off slow moving stock.
Posted on Oct 06, 2008
  • 3 Answers
SOURCE: I got a pink Fujifilm Finepix Z20fd and pictures won't download
You don't have to use the software that came with the Fujifilm. I have the same camera. If you're on a laptop that has a slot for SD cards, (if you have an SD card) you can just put your card straight into your computer and load the pictures that way. Also, if you have an SD card reader, you can use that. And if you're on a desktop without either of those options; once you plug your camera into your computer, go to your start menu and click 'My Computer,' then your camera should come up as a removable disk device in the folder. From there, you can drag and drop the pictures onto your desktop or your My Pictures folder.
Posted on Jan 08, 2009
Fujifilm finepix s9500 won't turn on with new batteries works in picture viewer with power adaptor but as soon as I turn switch fully on to take picture the camera just turns off
Hello my FinePix S9500 will not power up, i have - Fixya
www.fixya.com/support/t4079670-finepix_s9500_will_not_power_up
Feb 8, 2010 - Question about Fuji FinePix S9500 Zoom Digital Camera ... Mine willswitch to 'picture view' but when I turn the switch to 'camera' it all just ...
Fugi 9000s camara fix( won't turn on) - YouTube
? 1:17
https://www.youtube.com/watch?v=Hb8jiWFfXQs
Jul 1, 2013 - Uploaded by wakohelliott
Fugi 9000s camara fix( won't turn on) .... FUJIFILM FINEPIXXP50 - Head's UP - My New Camera - Full HD - Water, Shock, Freeze, Dust Proof ...
fujifilm finepix s9500 wont turn on ' Fuji X Forum
www.fujix-forum.com/.../fujifilm-finepix-s9500-wont-turn-on.49929/
1 day ago - Hi I am new on this forum and new to bridge/DSLR cameras I have been given a fujifilm finepix s9500 and it will not power on I have tried ...
Jan 01, 2016 | FUJIFILM Cameras
When i turn on my fujifilm s5500 i cannot take any photos or view and photos, if i format the card on the camera it than says card full. Than if i turn the camera off and than on again it comes up with...
I downloaded a PDF manual for your camera to make sure what I was about to say was indeed correct. My first impression/thought about this problem is that your camera Firmware is not capable of that size a memory card. I looked into the card capacity and according to the PDF manual you camera takes an XD - Picture card the capacity on the original Firmware is for 512mb here is a chart.
XD Card Max covers the S5100 and S5500 models
You may be able to go onto the Fujifilm web site and actually update your firmware.
Another thing that came to mind is that these cameras are often "clock" dependent and if the camera batteries have been removed for some time the clock date and time may also be giving an error. However my first impression is that the memory card is to large in capacity.
Jan 11, 2011 | Fuji FinePix S5500 Digital Camera
How do i turn on the flash?
Hello.
Welcome to Fixya.
In order to turn on the Flash on your FUJIFILM FinePix Z70 Z71 try to follow these Steps :
  1. Press the Flash icon on the right selector till you get the Mode you want.
  2. ready for use.
check the page 35 on the manual it's very useful.
Additional Help:
FUJIFILM FinePix Z70 Z71 User Guide.
Thank you.
Please let me know if you need any further Help.
Dec 18, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
Need a fujifilm owners manual for s5500
You can download the instruction manual in PDF format by clicking this link.
To download the Quick Start guide, click here
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Aug 04, 2010 | Fuji FinePix S5500 Digital Camera
Blank white screen on my fujifilm S5500 how can i fix this? it was working fine then one day i turned it on and all i got was a blank screen
CCD FAILURE !
just call FUJI in ur area they will do it free of charge even if u are out of warranty dont worry it is a known problem thousands are facing these days just call them and everything will be ok PLS RATE ME FIXYA for help
for support www.fujifilm.com
see this
http://www.imaging-resource.com/badccds.html
Apr 14, 2009 | Fuji FinePix S5500 Digital Camera
FUJIFILM FinePix A360
Nov 13, 2007 | Fuji FinePix A360 Digital Camera
Fuji FinePix S5500 Digital Camera Logo
124 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
