Question about Acer Aspire 5500 5570-2609 Laptop
Load os when i loading winxp then a problem like "76317mb disk 0 at id 0 on bus 0 on atapi ( setup cannot access thisn disk )
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sounds like the disk needs a format...
  • Acer Master
  • 1,183 Answers
There is a problem with the hardrive,on your computer. Have you got any Hardderive diagnostics cd given acer to you ?
Kindly contact Acer support if the system is still under warranty.
Thanks
proton
Posted on Oct 28, 2008
What's wrong with the hard drive?
Sounds like the HDD has either firmware issues or just faulty.
May 09, 2016 | Dell Inspiron Mini 9 Laptop
Problem setting up windows XP
D to Delete all the partitions on the drive to get all the space into one big contiguous space. Then try installing.
Apr 06, 2012 | Systemax Venture S519J (988868) PC Desktop
Setting up windows XP on Systemax venture computer says set up can not access this disk
If you installing a new windows you should first delete all partititons and then create one and install windows on that. Remeber all data on your harddisk gonna get deleted. So press d to delete and then c, then enter on the new partition
Apr 06, 2012 | Systemax Ascent PC Desktop
PXE-E61 media test failure on Acer Aspire 5050 laptop
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
Feb 08, 2010 | Acer Aspire 5050-3242 Notebook
Received
Try deleting all the partitions and perform the complete format instead of the quick format. Maybe this will help you.
Jan 03, 2010 | Dell Inspiron 9100 Notebook
I have a compaq presario sr1103wm and it won't load windows. i turn it on and it goes to screen saying windows wasn't shut down properly and lists the options: start in safe mode, with networking, with...
re install or repormat your system to fix all problem will return into normal operation... but before that dont forget to save your data if you have important data dont'want to loss it..
if can't open the program or operating system remove your Hdd then insert into another computer to back up the data ot be sure that you have back up all important data. except those programs cant make back up... you need to re install again from the source..
Sep 17, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Long periods of hard drive activity
Most likely, it could be the amount of ram you have in your computer. If your running low on ram and it is using the virtual memory your computer can be running all the time causing a slow down in whatever you do. Check to see how much ram you have :)
Mar 24, 2009 | Computers & Internet
Cannot install second disk of the vista premium recovery set that was installed by the toshiba manf. i can install other os vista basic/winxp pro i was informed by toshiba tech support previous to this...
they are telling u wrong thing how can it be ram if u are able to load other vista basic /xp ram doent know which OS u are loading this is un acceptable
try this to restore ur OS without disk if ur OS came pre loaded with ur machine
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls tell me the results if it helps or not and pls rate me FIXYA if u like
Mar 01, 2009 | Toshiba Satellite A205-S4617 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
