Question about Kenmore 24 in. 16539 Built-in Dishwasher
Hotpoint DF23: Wont go through full cycle
We have just bought a Hotpoint DF23 Dishwasher second hand and it will not go through the full cycle. Every time it gets to a new number on the dial it just stops.
It fills with water and washes and heats up ,dries etc just will not seem to go through the full wash.
Also, we do not have a manual for it nad wondered if anyone knew where we could get one?.
Hope you can help
Many thanks
Hi i have a hotpoint D23 11years old. Have just replaced the timer switch as it got stuck on the programme . The new switch has not cured the problem. could the new timer switch be defective or is ther something else I should look at.
Posted on Jun 24, 2011
  • 150 Answers
Sounds like you may have to replace the cycle timer.
Posted on Feb 22, 2009
Bought a LG LD 05AW2 benchtop dishwasher second
More than likely it is the electronic control board.
Feb 26, 2010 | LG Dishwashers
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
May 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dishwasher flooded
These 2 things that may happen
1.- the cycle was interrumped
to find out if this was the problem let the dishwasher go full cycle with out opening.
If this won't solve the problem let do a cleaning because
sound like is plug.
Wasth this helpful?
Apr 16, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Sep 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the may have a defective timer or your outlet hose is clogged or kinked.
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
The fuse in the plug keeps blowing. Initially it would run for a while - sometimes 3 or 4 cycles - before blowing. It now blows the fuse the second that I plug in to the socket, even with the on/off button...
Lower the outlet hose into a washing up bowl, it should then Drain. Check the heater to see if it is earthing you get to it by removing the right hand side panel.
Nov 28, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher will not go thru wash cycles
You have a problem which will need some knowledge of how the machine works and some test meter.There may be a problem with the motor.It may not beworking,jammed or dead -burnt out.The motor does the work after the water-cold,hot or medium-has entered.
The timer-you say works- will connect power to the motor to do its job,power to solonoid for the valves to open at the right time to let water in and out-pushed out by the motor.Remove the water with a cup and rags from the machine and then see if the motor turns by hand.This may mean you have to get under the machine.ALL WAYS REMOVE THE POWER CORD AT THE WALL POWER OUTLET--Jay
Nov 15, 2007 | Hotpoint 24 in. HDA2000Z Built-in...
Kenmore 24 in. 16539 Built-in Dishwasher Logo
462 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
