Question about Toshiba PORTEGE M700-S7005V T8300 2.4G 2GB 160GB DVDRW 12.1-WXGA WL BT WVB PC Notebook
Page keys don't work in BIOS
  • 734 Answers
Check your cmos battery?
Posted on Feb 24, 2012
Compaq Presario CQ57 keyboard function loss
leave the main huge battery out, until the PC runs perfect,
batteries this old are NO GOOD ! EVER! leave it OUT.
all things made by man fail out of the blue, all do, and x100 that on old things. it's called Entropy in Physics class.
Cq57 with the ending number missing why post this.
no OS stated, why ask , we can not guess full p/n nor OS. at all.
why not get tech to fix it?? like your car, it breaks, do you fix that.same thing here, PCs are complex.
but here is a list .
1: screen not dead. if yes, say screen is black totally .
2: you power on and go to BIOS,, and the keys work there Y/N.
No; the keyboard is no good, replace it. or the ribbon cable to it fell off.(deep inside , and tricky)
yes, see the keyboard does work in BIOS.
your BIOS keys are in your operators guide and service manuals
lost those, seem so, and so you must beg for long gone books>?
carbon date 2011, not that old.
the magic key is"ESC" press it like a wood-peckker bird at power button on, and quickly hit ESC, this is BIOS SETUP
HP calls it ONLY SETUP. but is BIOS setup on all PC made.
as see in your lost manual.
page 82 tells the secret key and now to do it)
http://h10032.www1.hp.com/ctg/Manual/c02786367.pdf
this is first, if BIOS screens work the major parts of the PC are ok
but not HDD or windows, unstated windows. xp or windows 7
xp is a virus magnet do not use it. online.
Apr 18, 2017 | Compaq Computers & Internet
HDD S.M.A.R.T Capability is disable appear on the screen when i try to open my pc
That is not a question......but SMART = Self-Monitoring, Analysis and Reporting Technology
It is a method which can be used to monitor the health of a Hard Drive and in some cases, provide enough advance warning that the user can save all their data and purchase a replacement BEFORE a catastrophic failure of the disk.
*IF* however, your question is how to "enable" S.A.R.T. on your Hard drive, then the answer is that that feature is enabled/disabled in the BIOS; though not all computers have that feature available. Yours does because it says that it is 'disabled', it really should be turned-on as it is, after all, there for your protection.
the make/model of your PC would help be more specific....but PC makers for desktops use a few keys for entering the BIOS on start-up, [Esc], [F1], [F2], [F10]....depends as I said on the make and model of your PC, but you can try them all, one should work.
Once you are in the BIOS, you would look in all of the areas, (usually it is in the first couple though,) for a S.M.A.R.T option....and follow the instructions at the screen bottom to change the value, sometimes the 'plus' or 'minus' or 'u' and 'd' keys sometimes 'page-up' and 'page-down' or others....
Then Exit, don't forget to 'save' when it asks.
Tallon41
Sep 17, 2012 | Computers & Internet
Checksum error on hp mini, how to fix?
Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program.
This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty.
It could also be another component on the motherboard.
Make sure the battery has plenty charge or remove the battery for a while, about 5 minutes to see if that restores it some motherboards cmos batteries are soldered in
You could check the site for the machine vendor to see if there is a reset jumper.
If that doesn't work then you will need to refresh the BIOS
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS.
To do that you need to press a key while the computer is booting Usually the Delete or F2 but can be other keys
It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one.
You will also need to reset the time and date.
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
Press F10 Save, Exit and re-boot and everything should then work
hope this helps
Sep 03, 2012 | Computers & Internet
Cmos checksum error-defaults loaded
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program.
hope this helps
Aug 03, 2012 | Dell Computers & Internet
Laptop will not boot message on screen: Waiting for ODDto become available
Reboot your system and watch the screen for which key it says to hit to get into the BIOS or System Setup (Probably F2), then hit that key when you see the message. Once you get into the bios look for and change the SATA MODE to 'COMPATIBILITY' .
If that don't work, you can look for AHCI and change it.
May 14, 2012 | Computers & Internet
Install english Windows XP on Japanese Panasonic CF-Y7. Simply insert OS CD and reboot does not help. Computer does not read CD.
The BIOS is probably configured to look for a bootable operating system on the hard drive before it looks at the CD drive. When you first turn on the computer, you have to hit a particular key to enter the BIOS setup (I don't know what it is for your model, but for most of the Japanese models I've seen it's the delete key. The startup splash screen should tell you what key it is. You have to hit the key before the splash screen goes away, otherwise it's already booting up from the hard drive.
Once you get into the BIOS, you can select the boot option page and move the CD drive up above the hard drive in boot priority. If the OS is in the Japanese language, the BIOS text may also be in Japanese. You can probably download an English-language BIOS firmware update to change that.
Oct 22, 2011 | Panasonic Toughbook y7 Notebook
Parallel port will not power up print server.
May be your parallel port is disabled in BIOS setup.
Enter BIOS setup (DEL key on some common boards, F1, F2, F8 or even F10 on some branded machines) to enter BIOS setup.
Use arrow keys, Enter key and Escape key to navigate through settings.
If Parallel port is disabled, press 'Page Down' button or '+' button (only one might work) to get an address for the parallel port.
Save BIOS and exit. Restart the machine.
Tell us the result.
Aug 30, 2011 | Tally Genicom 3810S Printer
Forget bios password
If you forgot your BIOS password, I'd recommend you to read, and follow the instructions foun on this page. Saves me a lot of time since I don't have to type it all, and since I don't spend time typing, you get an answer to your question faster.
Hope it helps. Good luck!
Jul 26, 2011 | Toshiba Satellite A105-S4384 Notebook
Toshiba PORTEGE M700-S7005V T8300 2.4G 2GB 160GB DVDRW 12.1-WXGA WL BT WVB  PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
