Question about HP DeskJet 5652 InkJet Printer
The printer selftest of my HP Deskjet 5652 gives error code 60000077. What does that mean?
While trying to print I got the message to load paper, although the printer has far enough paper. So, the printer refuses to print.
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
HP Deskjet 5650 - Troubleshooter keeps saying paper is low or out.
How to use the solutions in this document To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report. This step determines if the product hardware functions correctly. When you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting. Print a self-test page Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press and hold the Power button (c01602202.gif ).
  4. Press the Resume button (c01678098.gif ) four times. The self-test page prints.
c01733891.gif IMPORTANT : Try to print a self-test report after every solution even if the solution resolves the issue.
Mar 28, 2013 | HP DeskJet 5650 InkJet Printer
How to print test page for HP deskjet 5652?
Press and hold down the Resume button until the printer starts printing a self-test
page, then release the button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 16, 2011 | HP DeskJet 5652 InkJet Printer
Hp Printer 5650 Printing Failure My system: Mac 7300 upgraded with MaxPower G3, and a PCL USB & Firewire card. An alternate system tried was a Wallstreet G3 laptop with a USB card. Both systems were...
Print failure is a very common issue faced by users while printing a document. There could be many issues if you are unable to print from HP printer. But you don't need to worry, we are here to help you out.http://www.hptechsupportnumber.com/ HP Tech Support Phone Number 1 877 645 7494 HP Helpline
Feb 28, 2017 | HP DeskJet 5650 InkJet Printer
Everytime i print a document it loads the paper up then freezes, the resume light blinks and i have to press it for the paper to be taken out then it will load another paper and start to print the...
ing.there is a light sensor in the carrage unit to check the paper. if the sensor is not working it will eject the first paper and then start print
Sep 25, 2009 | HP DeskJet 5652 InkJet Printer
Hp deskjet 5652 not printing, orange light flashing continuously
1. Check to insure the cover is shut down completely.
2. If the "Ink Drop" Icon is blinking you are either out of ink, or there is a problem with the cartridge carrier. So open the cover - the carriage should move to the middle, if not it is bound up somewhere. Check the guides and around the carriage area for gummy labels etc..
3. If the carriage moves to the middle, release the ink cartridges and replace.
4. If the "Arrow" Icon is blinking, this could be a result of a paper feed error. Remove the paper from the tray, open the cover and insure no jams are in the rollers. Shuffle the paper lightly and place back in tray. Check to make sure the tray is pushed completely forward and then press the "Arrow" Icon button until a sheet is fed into the printer.
* * Note: When you are replacing the Ink cartridges and before you remove the tape from the bottom heads, give them a shake to lossen up the ink before installing.
This link will take route you to HP's support and more troubleshooting techniques for your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013363&lc=en&dlc=en&cc=us&product=304442&rule=35720&lang=en
Hope this helps..
God Bless.......
Jun 18, 2009 | HP DeskJet 5652 InkJet Printer
Message "Black cartridge is not compatible with this printer"
my problem is i upgrade my operating system from windows xp to windows vista and my printer ishp deskjet 5652. whenever i print my documents it became smaller the actual size. may i know how can i solve it.
Feb 15, 2009 | HP DeskJet 5652 InkJet Printer
Meaning of lights
You can download the manual from the link below: http://h10032.www1.hp.com/ctg/Manual/c00044028.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 10, 2007 | HP DeskJet 5652 InkJet Printer
HP deskjet 5652
Well, one way is to just take the paper out when it tries, and when it gives you an error message tell it to abort the print. Another way is that the second it starts printing press the power button, or cancel button if it has it, that will tell the printer to stop printing.
Aug 02, 2007 | HP DeskJet 5652 InkJet Printer
HP DeskJet 5652 InkJet Printer Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
