Question about MSI K8MM-V Motherboard
Sata Port Connector is not avtivating
I have MSI K8MM-V Mother. Till now i am using normal Hard Disk drive and the drive is working nice. Now i want to use a sata hard disk drive. in bios setup i have enabled sata drive but in standard setup in bios no sata drive is displaying. what can i do. is there any bios setup change. please inform me.
thanking you
my e-mail id is surojitshil@yahoo.com
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Posted on Feb 10, 2009
    President:
  • 2,351 Answers
Hi surojit,
I did check for any possible bios updates that may have addressed a SATA drive not found in bios for MSI's K8MM-V. http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=173
This is a very common issue with many manufactures of older boards. If you serial SATA drive is not being seen in the standard setup menu of the bios, yet your bios does show your IDE drive - (s). Than the serial ATA SATA controller (integrated into the board) is faulty. Note: If the SATA drive is 2.0 complaint / 3GBs SATA II, 2.0 specification. Chances are the pin settings on the SATA drive is already set to run at SATA II. Read the information on the SATA hard disk drive's sticker. See if you can set the drive to run at 150MBs, Serial ATA 1.0 specification. Than re-connect to the system. Check if the bios now see's the SATA drive. (This may be an issue with the MSI board), (Unable to see SATA 2.0 configuration only). However if after you drop down the drive to 1.0 spec & the bios still does not list the drive, than again the SATA controller is faulty. You do have an option of buying a SATA controller for a PCI slot. As seen at this link: http://www.valleyseek.com/product.action?itemID=668
A defective onboard SATA controller can not be fixed.
You can also buy a new board:
http://www.pcplanetsystems.com/abc/product_details.php?category_id=124&item_id=736
Good luck surojit!
Mike
Posted on Oct 28, 2008
Hi surojit,
Good luck surojit!
Mike
Will K8MM-V MS-7142 Motherboard supports 500GB Sata 3(6gbps) Hard disk, by setting to 1.5gbps speed ?
The designers of SATA aimed for backward and forward compatibility with future revisions of the SATA standard.[citation needed] To prevent interoperability problems that could occur when next generation SATA drives are installed on motherboards with legacy standard SATA 1.5 Gbit/s motherboard host controllers, many manufacturers have made it easy to switch those newer drives to the previous standard's mode. For example, Seagate/Maxtor has added a user-accessible jumper-switch, known as the Force 150, to enable the drive to be switched between 1.5 Gbit/s and 3 Gbit/s operation. Western Digital uses a jumper setting called OPT1 Enabled to force 1.5 Gbit/s data transfer speed (OPT1 is enabled by putting the jumper on pins 5 & 6). Samsung drives can be switched to 1.5 Gbit/s mode using software that may be downloaded from the manufacturer's website. Upgrading a Samsung drive in this manner requires the temporary use of a SATA-2 (SATA 3.0 Gbit/s) controller while programming the drive.
May 09, 2012 | MSI K8MM-V Motherboard
MSI K8MM-V Motherboard, How much support of Hdd capacity in Sata port
Apr 04, 2012 | MSI K8MM-V Motherboard
When I will going to install win xp(sp2) with sata harddisk its show no dsrive installed on your system
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 15, 2011 | MSI MBOX K8MM-V Athlon64/Sempron Barebone...
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
HOW TO INSTALL WIN XP ON SATA HDD ON MSI K8MM -V M/B
If your copy of Win XP does not recognize the SATA drive (i.e. Early copy of XP) you will need to use the F6 option and load the SATA driver that came with the MSI mother board.
Mar 24, 2010 | MSI K8MM-V Motherboard
How much total Hard Disk capasity supported by my motherboard
Since it supports 120GB, it will support any "large" SATA drive, such as 500GB or twice or three times that size.
Sep 20, 2009 | MSI K8MM-V Motherboard
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Unable to use SATA hard disk with existing IDE Hard disk
Hi abhinav13, please disconnect you're IDE. (do not remove it).
You're board only supports SATA 1.0 which is 1.5BG & not the SATA II at 3.0GB. Knowing that you may need to use the jumper to set the drive to 1.5GB. Once you are sure the drive is set correctly than hook it into the PC. If after disconnecting the IDE & SATA drive is shown in the bios. Set the jumper on you're IDE to function as a slave drive.
Enter the bios again. If you do not find the SATA drive listed than your onboard SATA controller is defective. You can not fix that.
So hate giving out bad news.
Luck!
Mike
Apr 09, 2008 | MSI K8MM-V Motherboard
MSI K8MM-V Motherboard Logo
1,423 people viewed this question
Top MSI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
