Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The top unit will not drain properly - Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
    Habit-Forming:
  • 17 Answers
Take out all the inside racking and spray arm. At the inside centre of the draw is a fan called the rotor. Turn the collar around the rotor and remove the big silver plate. Remove the rotor assembly by turning the new rotor collar. if you look at what you have left is a hole in the centre and a pool shaped groove closer to you. In that pool shaped groove is a small hole leading to the centre hole. You should find this hole is blocked. To unblock it i use a stem from a spray bottle e.g. the spray and wipe bottle. Stick it in from both ways and you should clear the blockage. NOTE there are two small holes going from the centre hole. Just one of these lead to the pool groove and gets blocked.
Posted on Feb 24, 2012
FDB1050REC2 no water
If water runs back into the drain then your drain hose is not properly afixed to the top of the unit under the cabinet. It must be at the top of the unit so no more than a half of an inch of water falls back into the tub when finished.
Dec 26, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidare FLXG52Rb won't final spin
Does the unit have a drainage problem? Do you notice the unit draining at all? Often when a unit does not spin it is because the unit cannot properly drain and dispose of the water and detergent solution.
Not over use detergent, this can result in oversudsing in the tub, and restricting the tub from turning properly.
That the drain hose is not too long.
That the drain hose is not restricted.
That the standpipe is not higher than 96" from the floor.
You may have defective timer or drain pump.
Also you might want to clean out the coin trap, filter trap, of the unit for extra security. This needs to be completed about every 6 months to prevent any issues.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 18, 2012 | Frigidaire FWS833A Top Load Washer
I have a LG LD 2140WH diswasher, it only works for 2 min then give a OE error code. what can be wrong
The possible reasons could be
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
May 27, 2011 | LG Dishwashers
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
May 02, 2011 | LG Dishwashers
Top load Maytag A882 will not drain after it has been filled.
clean the drain pipe line remove some foreign object inside the line that coz of blocking water going out,if clean but water not going out you need to replace the drain pump of your unit.lay down the unit check the small motor that connecting to drain line remove the screw and remember the exactly position of the parts before removing,after that buy a new one and return properly and carefully.,remind unplug the unit before anything to do.
Jan 01, 2011 | Maytag SAV5710 Top Load Washer
NewAir AF-350 is blowing water out the front louvers. Unit is 2 days old.
water normally condenses in the evaporator .. this runs down to a pan that drains to the outside section of the air conditioner .. there it it used to help cool the condenser and overflow runs out a drain in the back ... your unit is not draining the water properly to the back section .. that is usually caused by the air conditioner being being mounted with its top tilted toward the inside ... it should be level or slightly tilted toward outside for proper drainage ... its also possible that paper or other debree has clogged the drains inside the unit from the front section going to the back section ..
Jul 25, 2010 | Heating & Cooling
How do I check the oil level in the lower unit of a 70 hp Johnson outboard?
remove the bottom drain screw first then place a tube of the proper lower unit oil in it. then remove the top screw and gently squeeze the tube of oil and when full it will slowly come out the top drain hole. when it does replace the lower plug first then the top plug second. make sure the seals are in good shape and plan on changing the oil in the lower unit yearly for proper maintainence. make sure you buy oil designed for your particular type of motor. good luck.
May 29, 2010 | Boating
New LG 8000 btu a/c units are rusting
I have a similar situation with 66 a/c units in my motel. The problem is the drain valve in the back of the unit (near the compressor) does not function properly. It is supposed to open when the water temp (laying in the bottom of the unit) gets to 50 degrees cusing the drain valve to open and let the water out. The problem is the water never reaches 50 degrees when the outside temperature is in the 80's. So the water sets in the units. The fan sprays the water over the fan motor, heating element and inside the chasis causing it to rust from the inside out. I have notified LG and they are investigating it...... Amana has the same problems with their units which use the same drain valve and they have removed the drain valve in several motels in the area.
I would suggest removing the drain valve or wedging something under the little round plate so the the unit drains. Also make sure your A/C is tilted properly so the water runs to the back of the unit and drains.
Aug 19, 2009 | LG Electronic Window Air Conditioner
Water left in the units top & bottom
From what you describe, the drain hoses are not properly connected.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Feb 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer will not spin/drain properly.
a large load will sometimes get out of the top of the tub and cause the lid switch mounts to break and then the unit wont spin or drain. just look under the top and if you see the lid switch just hanging or not in the right place then replace the lid switch.
Dec 07, 2008 | Whirlpool GSC9455 Top Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
54 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
