Question about Dolphin 9500 (9500L00131C22)
Getting error 'Mobile SCM' is not a valid Pocket PC application
In trying to start Lawson MSCM application get error "Mobile SCM' is not a valid Pocket PC application
Tip
How do you Sync your Gmail contacts with a Windows Mobile
<p>The process of manually entering your Gmail contacts in the address book of your Windows Mobile smartphone can be time consuming. In fact, this process even more frustrating if you regularly move from one device to another. Fortunately, the sync option in most smartphones, including Windows Mobile devices, makes it easier for you to use your Gmail contacts for different platforms. In Windows Mobile devices, this option made possible by Google Sync. Google recommends to make sure that you back up all contacts and calendars from your phone to your computer before continuing. <br /> <p><br /> <p>1. Start the Microsoft Exchange ActiveSync application on the Home screen of your Windows Mobile device. <br /> <p><br /> <p>2. Choose "Set your device to sync", "m.google.com" in the "Server Address" field, select "This server requires an encrypted connection (SSL)" and choose "Next." <br /> <p><br /> <p>3. Enter your Gmail credentials in the "User Name" and "Password" box, leave the "domain" box unchanged. If an error occurs due to the abandonment of the "Domain" field is blank, enter "Google" box. <br /> <p><br /> <p>4. Select "Next", select the "Contacts", click "Finish" and then click the "Sync" softkey. You have enabled the synchronization of your Gmail contacts on your Windows Mobile device. <br />
on Aug 18, 2011 | Microsoft Windows Mobile 2003 for Pocket...
Cannot download whatsup on my samsung i900, based in namibia. Tried but gives me feedback saying not valid pc pocket application
do you mean whatsapp? if so, then that aplication does not support windows mobile operating system so you can't install it on your phone.
Sep 06, 2012 | Samsung Cell Phones
When i want to download any application from mobile the error appeared ''certificates not on phone or sim''please help
There are a couple of things you can do. Try to update your phone firmware using Firmware Over The Air, if your operator supports this.Re-install the phone firmware using Nokia Suite / Nokia PC Suite. This should re-install the certificates as well. If the problem still persists, visit your nearest Nokia Care Point. Let us know if this helps
May 13, 2012 | Nokia XpressMusic 5320 5...
Brother mfc-430w printer install problems vista
Start > Accessories > Command Prompt
OR
Start > Run > type "cmd.exe" (without quotes) and click OK
In the black window that opens, type "sfc /scannow" (without quotes) and
press Enter. Have your Windows XP CD handy.
If you don't have a WinXP CD, see: http://www.updatexp.com/scannow-sfc.html
Jan 04, 2012 | Brother MFC 240C All-In-One InkJet Printer
When i try to install any application on my HTC 3400i i am getting an error llike "Not a valid pocket PC software". Please help how do i rectify it. Thanks in Advance...
This problem comes when you try to install software on phone which are not compatible with your phone software version (Microsoft Windows Mobile 6.1 Professional), before installing any software kindly check the software support with your software version,
Like if you take the game from www.getjar.com, you will find a tab of compatible phones, down the list if you find your cellphone model, then it will install on your phone, otherwise it will give error,
If you require more assistance, feel free to reply to this post
Thanks for contacting FixYA!
Regards-BA
Feb 02, 2011 | HTC Touch Pro Smartphone
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
Installations
You may also try upgrading your os on the device this would clear up any problems. As far as i can tell it can only go up to Windows Mobile 3
Feb 05, 2009 | Dell Axim X5 Pocket PC
Installation of softwares
i hope the ipaq is a windows based mobile, or what is also known as pocket PC. If am right, then it will not support .exe applications. Google your requirements specifying that your's is a Windows based mobile..
please revert back for clarifications..
Jan 30, 2009 | HP iPAQ H6340 Pocket PC
Cannot install application on my pda2k
You need to check whether it's an .exe file or a .cab file. If it's a .exe you need to first install it on your pc nad then via activesync install it on your PDA2K. If its a .cab file you should be able to install it directly on th PDA2K. ps If you try to run the .cab file on your PC it will say its not a valid apllication with the corresponding windows error code.
Sep 21, 2007 | i-mate PDA2k Pocket PC
Dolphin 9500 (9500L00131C22) Logo
54 people viewed this question
Top Dolphin Computers & Internet Experts
David Payne
David Payne
Are you a Dolphin Computer and Internet Expert? Answer questions, earn points and help others
