Operating Manual for SPT Portable Air Conditioner Model WA-9020E
Model WA-9020E
2 Suggested Answers
SOURCE: Model M6P09S2A Maytag Portable Air Conditioner/Manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Posted on Jul 20, 2011
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
How do i get AC to work?
air conditioners and refrigerators work the same way. Instead of cooling just the small, insulated space inside of a refrigerator, an air conditioner cools a room, a whole house, or an entire business.
Air conditioners use chemicals that easily convert from a gas to a liquid and back again. This chemical is used to transfer heat from the air inside of a home to the outside air.
The machine has three main parts. They are a compressor, a condenser and an evaporator. The compressor and condenser are usually located on the outside air portion of the air conditioner. The evaporator is located on the inside the house, sometimes as part of a furnace. That's the part that heats your house.
The working fluid arrives at the compressor as a cool, low-pressure gas. The compressor squeezes the fluid. This packs the molecule of the fluid closer together. The closer the molecules are together, the higher its energy and its temperature.
The working fluid leaves the compressor as a hot, high pressure gas and flows into the condenser. If you looked at the air conditioner part outside a house, look for the part that has metal fins all around. The fins act just like a radiator in a car and helps the heat go away, or dissipate, more quickly.
May 26, 2012 | Sunpentown SPT WA-9040DE 9,000 btu Dual...
Need instruction manual for Sunpentown WA-7500M
You can get the manual on the link below I hop it will help you.
http://www.sylvane.com/images/productpages/sunpentown/manuals/WA-7500M.pdf
Good Luck and please rate 4 thumbs up for the free answer
Jun 19, 2010 | Sunpentown 7500 BTU Portable Air...
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
Why is my sunpentown WA-1210H portable AC not blowing cold air anymore?
Might be a dirty filter, a burnt compressor wire or a bad capacitor. Or it could be a bad thermostat.
May 10, 2009 | Sunpentown WA-1220E Portable Air...
Spt portable ac unit keeps tripping and will not turn on
Sounds like you have a short in the high voltage wiring. The compressor may be bad.
Mar 10, 2009 | Sunpentown WA-1220E Portable Air...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
