Question about Sentry Fireproof Safe
HAVE SENTRY SO410 SAFE WITH KEY BUT NO COMBO. HOW DO I OPEN IT?
    Scholar:
  • Sentry Expert
  • 170 Answers
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Posted on Nov 23, 2013
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
ginko
  • 19396 Answers
SOURCE: can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Posted on Apr 27, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a Sentry safe A3860.. I have the combo and
1. Insert a paper clip or pen point into
the small hole of the battery cover located
directly below the keypad. Push in while
sliding cover to the right (Fig. B).
2. Disconnect and remove battery holder.
• Insert 4 new AA batteries (not included)
to power this lock.
• Reconnect the battery holder and put back into proper
position. Slide battery cover back in place.
NOTE: The yellow LED will light when the batteries need
to be replaced.
You can also get the manual here on link below. page 1 tells you how to replace battery.
http://www.sentrysafe.com/pdfs/OwnersManuals/506218.pdf
Posted on Dec 22, 2009
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Posted on Mar 15, 2010
loxmith
  • 21 Answers
SOURCE: Safe SENTRY S3877 can not open the door
here is the number for customer service, 800-828-1438
Posted on Jul 24, 2010
I have a sentry s0410. I have lost the key and combination - how do I open the safe?
Sledge Hammer :)
Side note: In all sentry documentation it clearly states that if you lock your posessions in the safe and lose the key/combination, there is no master key or combo that will open your safe. You could try to write the good people at sentry but I haven't heard a success story from that yet.
My advice would be to befriend a firefighter and somehow convince him to let you borrow the jaws of life. Or get a hold of some explosives.
Good luck to you.
May 04, 2011 | Sentry Fireproof Safe
Lost the combo to my sentry 1610 safe, need the company master combo
Hi.
If you have lost the combination you need to follow detailed procedure needed to retrieve the key from Sentry. For security reasons there is no other way to get a master combo.
Please follow the instructions detailed in this link.
Regards.
Ginko.
Nov 16, 2010 | Sentry Safe Fire-Safe Personal Safe
I have the combo, but what is the direction? Do
Locksmith Instruction manual on how to dial open sentry fire safes.
NOTE: If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking Sentry Fireproof Safe open.
Nov 16, 2009 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Open my sentry safeBD374252*
Hi.
The only way of opening a sentry safe is by using a registered combo, or by contacting Sentry. There is no other simple and non destructive way to open a Sentry.
See here: Sentry respects strong security standards. There is no simple way of hacking a safe if you loos.
Oct 05, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
The door lock could be jammed try shacking briskly to losen lid and latch! akso it may have reset itself and the combo is no good no more and back to the origanal setting it had when you bought it ! ( if its a 911 you can put a screwdriver in where key goes and turn hard counter clockwise)
Good Luck!
Jan 02, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
1,202 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
