Question about Konica Minolta DiALTA Di200 Copier
Error c12co in minolta di550 - Konica Minolta DiALTA Di200 Copier
  • 146 Answers
C12CX (X is any value)
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Posted on Nov 11, 2008
Error Code c0045
Bop. Error Code c0045. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.officeimagingsystems.com/id169.html
Konica Minolta Di450 Error Codes
http://www.biz.konicaminolta.com/download/users-guide/c554e_c454e_c364e_c284e_c224e/en/contents/id16-_101076518.html
Aug 25, 2016 | Konica Minolta Minolta Di450 Di470 Di550...
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
Ho doI network a Minolta Di550?
Best Operating system would be Windows 95 maybe XP at best.. NOT good for Windows. Go to Konica Minolta web site see if you can get the drivers for that machine all call KMBS to see if they can help you
Go thG
May 05, 2014 | Minolta Di550 B&W Laser Printer
Minolta DI450 error code C-0920
1st paper draw lift motor is jammed or burn out or the control board is bad. Check for paper behind the draw, also remove any paper from left side of draw.
Dec 26, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di550 error code c-13fc
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Nov 19, 2013 | Minolta Office Equipment & Supplies
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Minolta Di550 Copier with a malfunction code of C-OF24
Hello sir; here have few steps need to follow;
1, press "function", press "printer", "F8" press "start" machine will run about 4 minutes the start key will turn from orange to green.
2, same procedure go to F5 will run about 30 seconds.
Jan 08, 2009 | Minolta EP1030/1030F CS/PRO Copier
"to test stapler, press staple button" ... Minolta di550 with FN-105 ... HELP !!!
First make sure that you do not have the collate and staple option checked on the printer menuing system or in the print setup on one of the local machines printing to it. Ensure that when auto-staple is not used that the error stops manifesting.
Then, I would check to make sure that you are installing the correct staples, length and width for the model.
Jan 23, 2007 | Minolta Di550 B&W Laser Printer
Konica Minolta DiALTA Di200 Copier Logo
662 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
