How do i wire a 2e206 thermostat? - Heating & Cooling
  • 499 Answers
RED IS 24 V POWER INTO T STAT
WHITE IS HEAT GOES TO WHITE ONN FURNACE.
YELLOW IS COOL GOES TO THE CONDENSING UNITS CONTACTOR WITH SOMETIMES MAKING A CONNECTION ON THE FURNACES LOW VOLTAGE TERMINAL BOARD, LVTB, BUT IT NEED NOT, AS IT DOE NOTHING HERE, IT DOES OUTSIDE WITH THE 24V COMMON OR NEUTRAL LEG OF 24 V POWER.
GREEN IS FAN/HIGH/COOL SPEED AND GOES TO GREEN ON THE FURNACES LVTB.
COMMON IS THE 24 VOLT NEUTRAL AND WHERE EVERY CIRCUIT TERMINATES OR ENDS TO COMPLETE THE CIRCUIT.
Posted on Feb 25, 2012
How do I wire a Honeywell thermostat
Can I start by saying I am not in anyway saying to do this alone it is dangerous but if u must follow each step start by being safe shut off the breakers good luck here to help
Step 1
Turn the air conditioning and heating unit off by flipping the appropriate circuit breaker. Test the unit to make sure it's off by turning your existing thermostat to the "On" position and seeing if it turns on. Wiring a Honeywell thermostat when the circuit breaker is on could cause you to blow the transformer that powers the HVAC unit Step 2
Connect the red wires to the thermostat RH, thermostat RC or thermostat R terminal. The thermostat RC terminal has a jumper wire between thermostat RH and thermostat RC. The thermostat R terminal operates both the heating and cooling units, and contains an internal jumper wire. Basically, your red wire on a Honeywell thermostat is the hot wire that run. Step 3
Run the green wire to the thermostat G terminal. The green wire controls the relay that operates the blower, and it controls the fan. Step 4
Control your air conditioning when you connect the yellow wire. It connects to the thermostat Y terminal Step 5
Hook the white wire to the thermostat W terminal to control the heating unit
Nov 20, 2014 | Heating & Cooling
My air conditioner thermostat keeps losing power
The power for thermostat come to an from the thermostat with the red and common wire. Check for proper connection to thermostat and check thermostat wire from the thermostat to the air handler. Technicians sometimes do not install splices well and sometimes the splices comes loose. I prefer using rtv loaded wire nuts to make splices when I can find them. Another cause for this problem is bad insulation on thermostat wire allowing wire to short out. If this is your problem, you need to replace the thermostat wire itself. If these do not fix your problem, you may need to replace the thermostat itself.
Hope this helps
Oct 20, 2014 | Heating & Cooling
How do i wire analog thermostat to digital
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
Jan 20, 2018 | Dometic Rooftop RV Air Conditioner
Dpsr483ea1ww how to replace thermostat
  • Unplug the dryer's power cord from the wall connection. You will be working around the dryer's wiring, which can be dangerous if the power is connected.
  • 2
    Remove the rear cover of the dryer. Most dryers have four screws, one at each corner. Flathead screwdrivers will work for most models, but some require Phillips-head screwdrivers.
  • 3
    Locate the thermostat. The thermostat is circular or oval with a wire connection on each side. Remove the screws keeping the wires connected to the thermostat. Set them aside--you will be reusing them to install the new thermostat.
  • 4
    Disconnect the thermostat from the wires, then unscrew the thermostat from its mounting bracket. The thermostat will easily pull away from the wires once you have removed the screws. Discard the old thermostat.
  • 5
    Install the new thermostat on the mounting bracket. Be sure to tighten the screw enough to keep it secured. Connect the wiring to the thermostat and reinstall the screws to hold the wiring in place.
Jan 13, 2012 | GE Dryers
We are trying to install a new thermostat for our heating and ac. and the wiring colors are different.
Hello my name is Heath it will be my pleasure to assist you. Red wire to R terminal on the urnace and the thermostat. White furnace and the wire to W or w1 on the thermostat nd the furnace, Use the brown wire on the W2 terminal of the furnace and the thermostat., Yellow wire to the y or y1 terminal on the furnace and the thermostat, Green wire to the G terminal on the furnace and the thermostat, Use the black wire to common on the furnace and the C terminal of the thermostat, Use the blue wire on the Y2 terminal of the furnace and the thermostat if you have a two stage air conditioner.
Sep 11, 2011 | Heating & Cooling
How do you install the thermostat?
Sep 05, 2011 | Heating & Cooling
How to wire condenser and air handler to the t-stat
Assuming this is a standard unit the thermostat connections you will use: Y, R, G, W and possibly C.
Run two conductor thermostat wire to the condenser. The condenser will have two wires to connect. Connect the two conductors to the condenser wires and run them in to the air handler.
At the air handler, connect the two condenser wires to: Y (yellow) and C
Run 4 or 5 conductor thermostat wire from the air handler to the thermostat. At the thermostat, connect the yellow wire to Y, the white wire to W, the green wire to g, and the red wire to r.
At the air handler, connect the thermostat wires: White to w1, yellow to Y, green to G, and red to R
*Y will now be connected to the thermostat and the condenser
*If you have 5 conductor wire to the thermostat, connect the last wire (which is probably blue) to C
At the air handler, connect the last wire (blue) to C. This will enable you to have 24 volts at the thermostat in case the thermostat actually requires 24 volts to operate it.
R=hot
G=fan
Y=cool
W=heat
May 19, 2011 | Heating & Cooling
With fresh batteries, the thermostat works fine, but after two or three days, the thermostat fails to turn on the furnance after the temp drops below the setting. Replace the batteries, and it works for a...
If you have a spare wire (unused) in the thermostat wire sheath you can eliminate the batteries as the power source.
Turn off the power to the furnace.
Open the thermostat and look for terminal "C". If it is not being used,then
look inside the furnace for the thermostat wire terminals. Black or blue are probably not being used. Take one of these wires and strip insulation back 1/2 inch. Connect this wire to the COMMON (C)(-)wires from the low voltage transformer.
Open the thermostat and connect the same wire to the "C" terminal on the thermostat.
Dec 22, 2009 | Honeywell Programmable Thermostat Heater
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
Heating & Cooling Logo
197 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
