CPU's Whats the difference between a 3.2Ghz intel celeron (per say) and a 1.6Ghz Intel core Duo? Is there a speed diff? if so, why?
  • 849 Answers
It is the definately speed difference, celeron is the old technology with low bus speed, a core duo is the lattest technology with high bus speed.
go for duo
Posted on Oct 28, 2008
I have been given a acer aspire L320 BUT THERE IS NOT A PROCESSOR IN IT. what i want to know is what processor fits.it
The Acer Aspire L320 can take 3 different processors
1. Intel Core 2 Duo
Dual Core chip with speeds from 1.8Ghz to 3.3 Ghz
2. Intel Celeron D
Dual Core chip with speeds from 1.6Ghz to 2.7Ghz
3. Intel Pentium 4
Single core chip with speeds from 1.3Ghz to 3.8Ghz
The Core 2 Duo 3.3 Ghz is the most expensive and Pentium 4 1.3 Ghz the cheapest.
Some more information is available on the Intel website, links are below:
http://www.intel.com/products/processor/core2duo/mobile/index.htm
http://www.intel.com/products/processor/pentium_dual-core/specs.htm
Hope this helps. Thanks for using Fixya.
Jul 13, 2011 | Computers & Internet
What model of cpu is this motherboard (Intel DG31PR) designed to accept?
Hello Kbda,
Intel DG31PR Motherboard support the cpu of following types Intel® Core™2 Quad Processor, Intel® Core™2 Quad Desktop Processor, Intel® Core™2 Duo Desktop Processor, Intel® Pentium® Desktop Processor,Collapse to hide the details Intel® Celeron® Processor, Intel® Celeron® Desktop Processor, Intel® Celeron® Dual-Core Processor, Intel® Xeon® Processor.
Also visit the link provided below :
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=dg31pr
Jul 08, 2011 | Intel DG31PR Motherboard
Can I upgrade my CPU to an Intel Core 2 duo 1.7
You are basically limited to what was optional on the model. So you can only upgrade to one of the following cpus:
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
And you are limted to 2gb of ram max on this model.
Apr 12, 2010 | HP Pavilion dv1000 Notebook
CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Sep 06, 2009 | Intel Computers & Internet
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Sep 05, 2009 | Acer Computers & Internet
Hi all i have a little question about CPU IN A9RP
if it will fit in the cpu slot, you can. But beware all chips have different number of prongs and only the chipsets that fit the number your slot has labeled on it. You have to some reasearch.
Sep 03, 2009 | Computers & Internet
Difference betweeen intel celeron,core duo, mxx
Hello , Intel processors come in all shapes and sizes so I'll try to be brief by discussing only the ones that are current on the market. The market for intel processors are currently divided into 2 sides. One side if for single core processors while the other is for multi-cores. Single cores: Pentium 4, Pentium M, Celeron, Core Solo (Not very common) These cpus are single cores meaning that they only have one processor. They are relatively cheap compared to multicores. The difference between these are clock values, hyper threading, 64 bit support, and FSB. Pentium 4 and Celerons are cores found in desktops while the M is found in laptops. Single cores generally have low FSB but high clock speeds. Think of it as having a lot of water pressure but only a straw to dispense it. That's how fsb and clock values work. So single cores should provide you with a lot of raq power but they're not good at multi-tasking or jobs that requires it divide it's attention. Games like Crysis will be better with multi-cores because the pc has to generate so many different things at once while focusing on countless calculations and processes. the hyperthreading support does help the single core pentium 4s with multi-tasking but it's not as much as multicores. So if you're just looking for something with a lot of raw power. These are for you. Multi-Core Core Duo, Core 2 Duo, Core 2 Quad These are multi-core processors developed by intel. They are used in both laptops and desktops except for the quad. It's used in desktops only. The first 2 processors are dual cores while the last is quad cored. These processors have a high FSB rating and generally lower clock speed. So you have to be careful when looking at these. The high fsb means that the system does really really well with dividing and transferring it's processing power, but if you get a low clock speed then there's not enough power to begin with for the assignment. Example you may have a large hose but if you have low water pressure.. it's useless. That's why multi-cores are great for the modern pc user who multitasks way too much but if it's under 2.0ghz in clock speed. You should be worried about not having enough raw power to get you through intensive work. Multicores generally cost a lot more than single cores since they're relatively new technology. Btw the Core 2 Duo is faster than the Core Duo by about 7%. Meanwhile the quadcore is the ultimate in processor goodness but costs $400+. I hope these facts helped.
Jun 10, 2009 | Intel Computers & Internet
Re aspire 7104 being upgraded to duo core processor
No it cant be updated
Your acer aspire is based on the 910GML chipset
The Mobile Intel® 910GML Express chipset is optimized for the Intel® Celeron® M processor.
Here you can compare the 910gml chipset and 945 which is used by the core 2 duo.
http://compare.intel.com/pcc/showchart.aspx?mmID=22210,7419&familyID=7&culture=en-US
As you can see on the page there are key difrences between the chipsets other runs on ddr2, yours on ddr. the FSB support is 400 on yours and 533 / 667 on the 945.
also you can see the supported processor familys right there.
you can look for a
Intel® Celeron® M processor,
Intel® Celeron® M processor Ultra Low Voltage (ULV)
Upgrade cpu with maximum FSB of 400MHz
Apr 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
150 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
