How do I replac the thermo-couple on a valor homeflame unigas
SOURCE: Have Valor Homeflame Unigas fire that will not
Have you tried changing the 9V battery under L side panel?
That's what was wrong with mine.
Cheers
Posted on Apr 25, 2010
  • 3315 Answers
SOURCE: bought valor homeflame super off a friend gas
google valor you should be able to get manual off there site you will need model number
Posted on May 02, 2010
SOURCE: instalation manual
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Posted on Oct 04, 2010
SOURCE: cannot get the pilot light
Is the clicker making the clicking noise? If not, it is most probably the spark generator which houses the battery. The part is still available online for about £40. It did the job for me.
Posted on Dec 20, 2010
  • 4736 Answers
SOURCE: Valor flamenco unigas 2 fire
Valor uses either a Thermocouple or Thermopile, depending on the unit. In some cases, it has both. And, yes, your assumption is probably correct. Some thermocouples are a part of the Pilot Assembly, which means you have to replace entire pilot assembly. If you check you Owners Manual in the Parts Breakdown section, it will indicate if it is or not and whether you need a Thermocouple or Thermopile or both.
If you're not familiar with repairing gas fireplaces, replacing the parts listed above, can be a little challenging. Especially if you don't have the proper tools. But, before you jump on this project, try cleaning the Pilot Orifice first. You can easily do this, using canned compressed air with a straw nozzle (like you clean your computer with) by blowing out the pilot tip. And while you're at it, clean all around the pilot assembly with the canned air. If cleaning the pilot solved your problem, you're back in business. If it didn't you'll have to go the other route.
Hope this helps you solve the problem. Please be kind enough to rate my reply to you. Thanks!
Posted on Mar 24, 2011
My Valor fireplace won't turn off with the remote
Easy turn the gas cylinder close then its off,Or you could have a faulty control valve or thermo couple .Thermo couple is the small device looks like a probe to detect heat this is normally directly in the small pilot flame.The pilot flame if not burning will not open the control valve for the other burners to come on.If the other burners come on but do not go of when turned off. then need to check control valve.
Jan 06, 2014 | Televison & Video
Valor flamenco unigas 2 fire ignites but wont stay on, assume this thermocouple problem how is thermocouple replaced
Mar 24, 2011 | Heating & Cooling
I have an old valor homeflame fire could you tell me how tha logs are put in position please
Here's a link to the Valor website home page.http://www.valorfireplaces.com/
Click on the Downloads tab and you may find the Owners Manual for your gas fireplace. It will show you how to install and arrange the logs properly. If you can't find the model you have, on the manuals page, use their contact information and call them.
Hope this helps you.
Feb 18, 2011 | Heating & Cooling
Can I fit a Valor Homeflame Harmony gas fire with a class 2 flue?
Just for information ... whether you're doing it as a 'B' -Vent (Straight up) or a Direct Vent (Straight out the back), it requires an appropriately sized Coaxial Vent Pipe. A Coaxial Vent Pipe is a pipe within a pipe, That has an air space in between the inner and outer pipe. Of course it will also need the appropriate termination cover.
For for technical advice on proper venting go to http://www.valorfireplaces.com
Feb 08, 2011 | Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
Cannot get the pilot light to ignite on my Valor Flamenco Unigas II when the ignition knob is pressed down. Have had the ignition battery out, but the voltage seems to be correct. Fire Serial No 005 344 No...
Oct 10, 2010 | General Heating & Cooling
Bought valor homeflame super off a friend gas fitter won't fit until he gets istruction maual
May 02, 2010 | Heating & Cooling
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
cheers
sharron
Mar 08, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
