Question about Frigidaire GLTF2940ES Front Load Washer
Error code ddo
I am having an error code of "ddo". does anyone know what this means?
  • csabbatino May 11, 2010
    I have this problem. But I can't find the magnet or where it is supposed to fit. Can you tell me where to find it? If it is lost, I might be able to fit another magnet it its place if I know where it goes.
  • ellen galvin Oct 24, 2011
    where exactly does magnet go please. I found the magnet
    Sergeant:
  • 276 Answers
The dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
Posted on Nov 18, 2008
MACHINE FLASHING DDO CODE
Hi Friend, this is Z. Thank you for allowing me to assist you!
Generally, error code DDO means that the dispenser drawer on your unit may be open. If so, close the drawer and the error code should resolve itself.
If you've double-checked the drawer and it is closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your appliance.
Jul 12, 2014 | Electrolux EW1200i Front Load Washer /...
Error code DDo ON A FRIDGEDAIRE FRONT LOAD WASHER
Hello geraldinerid - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a further diagnosis is recommended to have a professional check the reed switch.
Apr 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
This washer has an error code of DDO, Dispenser door open, would you think a sensor issue or something more?
The meaning for ddo error means"Dispenser Drawer Open" .To rectify this problem you should try opening and closing the door shut. There will be a magnet which shows that the door is closed or open.The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself to view the magnet. If the magnet is missing you have to replace it.
Thank you !!
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
My GLTF2940ES0 WON'T START it's cycle. An error code "ddo" displays
The meaning for ddo error means "Dispenser Drawer Open"
Thank you !!
Jun 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
The water wont start filling up - it beeps and then has the code "ddo" on the screen.
Thank you !!
May 25, 2010 | Frigidaire ATF6000ES Front Load Washer
Ddo
Hi
This ddo error code means Dispenser Drawer Open.Check to see if the Dispenser Drawer is open or the small tubular Magnet # 51 is missing. The magnet is underneath the dispenser door, you have to remove the dispenser from the washer, then take apart the dispenser itself, you will see snapping clips to unsnap, then you will see the magnet#8 in diagram#1 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=117979
reference
http://www.fixya.com/support/t2180388-code_ddo
Mar 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Code ddo
Hi
This error code appears in the frigidaire washer which means--
ddo error--- Dispenser Drawer Open
GLTF1670AS0
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 08, 2009 | Washing Machines
Frigidaire + ddo error code
Excellent solution. I had a similar problem. The trick is to figure out where to put the magnet. I had a hard time with that.
For those like me who might have difficulty finding the spot for the magnet, it goes on the right hand side of the detergent door. The easiest way to do it is to pull the detergent door all the way out of the machine and look at it such that the back of the door is facing you. The magnet fits vertically in a slot on the left side as you are looking at the door (right side of the doorwhen inserted in the machine) in the white plastic. It sits vertically and is held by a small latch. This is not obvious at all...
Jun 25, 2008 | Frigidaire GLTF2940ES Front Load Washer
Our washer has an error code of DDO.
ok if it is the rigt thing for that code there will be a switch on the door have a pen or some thing you can use to trip the switch to thinking the door is closed. and unplug the unit and replug it in.. todays age every thing has to rebooted
Dec 16, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
300 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
