Question about Toshiba (MK4004GAH) 40 GB Hard Drive
I need to know the exact pin numbers to power on a toshiba mk4004gah
I just recently got this hard drive from a friend for free and he didn't know if it worked or not so basically I need to know the pin numbers that power on the drive to see if it works or not I've done a massive google search and come up with barely anything. I don't want to waste money on a usb enclosure for such an uncommon drive is the reason I'm trying to do it this way i know it's power rating is dc 3.3v 500ma and i do have an adjustable power supply that will do it. Any help is appreciated although I don't think anybody will find anything more than I did.
Thanks in advance
  • 2 more comments
  • dankajell Oct 28, 2008
    yes i just want to see if it works or not I'm not about to spend money on something that's trash.
    no i just want to hear the motor spin up correctly then shut it down, before i spend money on this size drive, and get the usb enclosure for it.
    Thanks for your help
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    well..works is an interesting issue..you can power it up, but without the interface cable, there is little chance of it doing much..
    so, you are asking for the dc connector pin out?
    New Friend:
  • 29 Answers
If it's a SATA drive, the power connector is the longer one. Pins 1-3 are 3.3v Pins 4-6 and 10-12 are common, Pins 7-9 are 5v, and Pins 12-15 are 12v. If its a IDE drive, the power connection uses a molex connector. Yellow (pin 1) is 12v, Red (pin4) is 5v, Black (pins 2,3) are Ground (common).
Posted on Apr 19, 2017
SOURCE: Need to format harddrive on Toshiba Satellite Pro 4300
here are a couple of links so ya can get a handle on things.... Just follow the instructions ya be all good.... http://72.14.253.104/search?q=cache:0sWcmSlxdlwJ:lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php+tutorial+to+format+laptop+hard+drive%3F&hl=en&ct=clnk&cd=2 www.youtube.com/watch?v=CEhbmJbAjPw
Posted on Aug 17, 2007
SOURCE: Portable Hard Drive will not respond / install
how many wattage had your computer? you need to upgrade your power supply.you need also to check your bios setup on usb port
Posted on Oct 03, 2008
lserni
  • 466 Answers
SOURCE: I have a Toshiba HDD2190 C DC +5V 0.7A 40 GB
In general, you need to install the correct drivers for the enclosure, not for the hard disk. Seeing as you have XP Pro, this is probably unnecessary though.
Also, 0.7A is 700 mA, and this exceeds the USB port maximum current which is 500 mA.
Most (not all!) laptop drives will run even if under a slight undercurrent, but this depends on USB port electronics and enclosure electronics.
Chances are that you won't be able to run the disk unless you plug it into an externally powered USB hub supplying at least 750 mA per port. The 100-500 mA supplied by your PC's USB port is enough to power the enclosure electronics and the host controller, but not enough to get the HD to spin properly. As a result, the HD can not be initialised and the enclosure will report an error.
Some hard disk enclosures come with a "USB Y Cable" or "double power cable" which joins two USB ports to get double the current, and can support HD up to 1.0A. If your enclosure comes with one of them, try that first.
Posted on Nov 02, 2009
  • 236 Answers
SOURCE: External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
Posted on May 08, 2010
How do I reset my iPod?
You plug it into the computer and launch itunes. Go the the iPod window and press restore.
Nov 07, 2012 | Apple iPOD 40GB Toshiba Harddrive for Gen...
IPod gen3 stuck in the Do not disconnect mode and the computer does not recognize it.
check the cable connection, for the hard drive that not recognized by computer, usually the problem is come from the cable connection not connected properly
Feb 22, 2011 | Apple iPOD 40GB Toshiba Harddrive for Gen...
I have a Toshiba (MK4004GAH) 40 GB Hard Drive which was taken out from a Old Toshiba Laptop. I bought a 1.8" IDE casing with USB and connected to my new laptop....however, it fails to detect the HDD....
You have to make sure that you have connected the HDD in the right way. Please open it and ensure that you placed the disk rightly into the casing with each pin tapping the rightful hole, see the casing's small manual. Note also that the laptop has to detect the casing as well, so cross check the casing to ensure that its working.
Dec 03, 2010 | Toshiba (MK4004GAH) 40 GB Hard Drive
Computer does not recognize my ipod
pls configure your apple so that your computer can recognize your ipod
Mar 07, 2010 | Apple iPOD 40GB Toshiba Harddrive for Gen...
Which connection hastToshiba MK4004GAH Harddrive
its a SDD 1,8" Harddrive The connector is ATA-5.
The drive has no moving parts and is built on
same basis as memorycards.
This is your solution! Please vote!
Jan 24, 2010 | Toshiba (MK4004GAH) 40 GB Hard Drive
We need the cable from the disc drive to the USB port so we can read.
any store that has computers will have this cable, u can also get them on ebay very cheap
Dec 09, 2009 | Toshiba (MK4004GAH) 40 GB Hard Drive
My ipod says www.apple.com/support/ipod comes on and shows battery with lighting bolt. then gos to www.ipod/support/.com
Actually the hard drive may not be "screwed" at all you should go to the following web address and view the free video on resolving your issue. Please let me know how it turns out. :)
http://fixyouripod.weebly.com/
Mar 08, 2009 | Apple iPOD 40GB Toshiba Harddrive for Gen...
MK4004GAH troubleshooting
define "dead" is it merely a failed partition, or bad sectors on the platter itself? if its bad sectors in some cases you can send it away and the will change the steel disk itself, but usually it costs quite a bit to have done, if its just a dead partition, you could plug it into a system as a slave, boot to a windows XP disk, destroy the damaged partition and simply lay a new one..
Dec 06, 2007 | Toshiba (MK4004GAH) 40 GB Hard Drive
Toshiba (MK4004GAH) 40 GB Hard Drive Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
